Leaning back towards Scoots...
Re: Leaning back towards Scoots...
Don't think Lyn has fitted his yet Mark
He picked up power by 'tapping' into the brake light switch.
Picture & info taken from ........ http://x9ownersclub.co.uk/forum/index.php?topic=26393.0
“Life can only be understood backwards; but it must be lived forwards.”
Ta for that. Will have a think, there must be a way to do it. Mine usually runs off the 12v socket
Apparently the glovebox (where the power socket is located) is watertight & getting a cable out will break the integrety of the seal
- Meldrew
- Current Ride: Honda Forza 300 A
According to my learned friend and fellow Forza owner Brubaker, that's only how Mr Milnes could power up his his TomTom bud.
We both found we could simply plug a Garmin lead into the 12v socket and close the door of the glovebox without damaging anything.
So that's what I'm doing and mounting my Zūmo on the right handlebar using the redundant threaded mirror holes and some RAM Mount gear. I'd prefer using the left side nearer the socket but it has a fatter switch cluster because of all the extra switches and it prevents it. If I don't like that set up I'll go to an alternative I've been considering.
I had an NC and it had watertight storage, the cable coming out of the top of the storage didn’t cause a problem waterwise, not a drop got in.
There are redundant mirror holes to use? Hmm.. that sound like a good plan....
Ram mount on brake reservoir has just been suggested
- poldark
Don't like those unless no other option, but that's just me.
They're obviously not central and always been nervous about potential stress of additional weight on the master cylinder. Though I've not heard any scare stories.
P.S. Welcome to Muppets.
- Meldrew
I have a RAM Mount brake reservoir in as new condition in a storage box labelled 'Useless S****'. I used it once on a touring trip with my Garmin Zūmo, Touratech cradle, and RAM arm set up. Even with longer screws supplied, the weight slackened them off and required regular tightening to prevent brake fluid leaking out the reservoir lid. It got so annoying that I had to use cable ties and electrical tape to keep the lid on,
- philboulter
- Current Ride: Bergman 650
A mate of mine has just bought a new Xmax and is not happy at all with the headlights. He is jealous of my Burgman 650 which has brilliant headlamps (pun intended) and frankly trumps the Xmax on all fronts.
I cannot comment on the Forza, but I am more than happy at the moment with the Burgman. It accelerates to overtake anything on the Motorway effortlessly - and I am 20 stone.
The one down side between our two bikes - his XMAX125 gets 98mpg - and I am getting 59mpg on my 650
As for the SatNav - I use the Oxford Flexible option between the handlebars - it works fine - and is totally waterproof.
59mpg!
Dream of that with my Burg. Mind you I do ride a tadge faster than most
