Suzuki Burgman (99-2002) Front Brake Rotor
SpudRider
Post by SpudRider »
Hello from Idaho, USA.
I believe the EBC MD929D, front brake rotor for the 99-2002, Suzuki Burgman 250/400, will fit my Chinese motorcycle. However, I need to verify the diameter of the circle which contains the bolt hole centers. If anyone has a set of calipers, he can measure the distance between the centers of two, opposite bolt holes without removing the front wheel. If someone can make this measurement, I would truly appreciate receiving this information. Thank you. ;)
The Bern
Current Ride: Silverwing 600
Re: Suzuki Burgman (99-2002) Front Brake Rotor
Post by The Bern »
replied to the identicle post in the introductions section
Have wheels, will travel :D
SpudRider
Post by SpudRider »
Thank you for both replies. :)
I always try to avoid duplicate posts. However, I originally attempted to post my question in this forum, but did not succeed. Therefore, I concluded I must place my first post in the Introduce Yourself Forum. After I successfully placed my first post, I decided to try posting again in this forum. I do not wish to clutter your forums, so I will refrain from more duplicate posts.
I have confirmed the outside diameter of the brake rotor and the inside diameter of the mounting flange. I have contacted EBC USA, but they could not provide me with the information I seek. :? I have also posted my question on the BurgmanUSA forum, but the Suzuki Burgman was not exported to the USA until after 2002.
I will now contact the EBC headquarters in the United Kingdom as well. Sometimes large companies are slow to reply, or will not reply at all to such inquiries. Therefore, I am hoping someone who owns a 99-2002 Suzuki Burgman will make the measurement for me. :)
I own a 2015 Zongshen RX3, which was sold in the United Kingdom as the Honley Venturer 250. However, I no longer see the bike listed on the Honley website. Here is a recent photograph of my motorcycle, which was taken in the bike's habitat of Idaho. ;)
Ow! i do like that picture, my kind of ride to.
Lyn.
SpudRider
Post by SpudRider »
Thank you, Lyn.
Here is another photograph, taken at Bear Lake, which is located on the Idaho/Utah border of the USA.
Whatsisname
Current Ride: Burgman 400 K5
Post by Whatsisname »
This site says it's 142mm between centres. Good luck!
https://www.ajsutton.co.uk/product/EBC/ ... GwodF2MMng
SpudRider
Post by SpudRider »
Whatsisname wrote:This site says it's 142mm between centres. Good luck!
Thank you, kind sir! You have confirmed this brake rotor will fit the front wheel of the Zongshen RX3. :D
