I've been using the Joymax in the wet lately and had the rear end slip out a few times, I've not been pushing it and have done the same bends in pouring rain much faster on the old S-wing with no problem!
I'm wondering if it's the tyres (Avon Viper Strike), the bike being much heavier than what I'm used to or if I have just been unlucky with oil on the road?
Tyre looks in good condition inflated to 32, might over inflate it as it feels more 'wobbly' when I was pulling the tyre to see if there was any movement in the wheel.
Rear tyre slipping
- Current Ride: s wing
Re: Rear tyre slipping
Video of it slipping...
I had same with vyperstryke years ago came off broke wife's arm in france not used them since .We're fine in dry.Our off was on a French traffic island
Shame because its got loads of tread and the dealer put a new one on the front when i got it, might see how much for a pair of City Grips then...
I brought 2 rears first one delaminated tread came up like petals on a flower second one we came off .We were loaded up which didn't help but day before in dry sunny weather had been fine.I brought a scooter with one on rear was just very causious with it in the wet .I still used it till it needed replacing tho .
- irev
- Current Ride: AN400
With tyres confidence is everything. If you have no confidence in it, change it.
irev is right, I had those avons on my old B125 and riding on them in wet started to wear away my confidence as the feed back from them was too vague.
Much like riding on my 6-7 year old bridgestones that I had on my TMax (the tyres had only done 900 miles in that time) when I first got it and changed recently, fine in the summer but in the wet they were feeling dodgy, vague and had worn badly through the summer due to age. New Bridgestone SC's put on in November and I am leaning over in the wet with confidence again.
- Current Ride: T-max mk6
You've answered your question yourself. Avon Viper Strike. Unless they've improved dramatically over recent years, Avon scooter tyres are appalling. (Bike tyres, made in UK, are fine, I believe). Many people have reported difficulties with them, especially in the wet. I had a pair of the radial versions on the mk2 Tmax and they were so badly made they were dangerous.
So, its not you, its them! Throw 'em away and get something better from Michelin, Bridgestone, Dunlop etc.
Looking at the video frame by frame, the wiggle happens as you cross a change of road surface.
The giveaway is the faded section of double yellow lines exactly level with what looks like a stain across the road.
It wiggles as you pass onto the older more worn surface.
Sure looks horrible though!gn2 wrote:Looking at the video frame by frame, the wiggle happens as you cross a change of road surface.
