More troubles
- Current Ride: T-max mk6
Re: More troubles
Latest news is that having it done is 'only' £350-400, so a bit less than I feared. I think a new barrel assembly is around £100. Its a lot for a repair, but otherwise I'd have to fork out far more for a replacement scoot which I don't really need, so it might be worth having it done. And who knows what troubles a different scooter might bring? The Bev is worth around £1k, so at least I wouldn't be paying out more than its worth!
- 2wheelover51
Re: More troubles
Mr G while you're at it with the new barrel and piston you may as well have that turbo kit fitted for a bit of extra boost..and it'll mop up your underspend
Re: More troubles
Hmmm it goes well enough as it is! What it needs is better handling and more grip!!!
Re: More troubles
PS and I'll need all my 'underspend' to pay for the Tmax replacement!
Re: More troubles
Latest installment....
The workshop suggested that it might be worth trying to plug the leak using Radweld or similar, on the basis that it might work, but if it didn't you'd have hardly lost anything. Well, I put some in and it does seem to actually worked and stopped the leak! However, there seems to be some uncertainty about how long this will last ie whether its a short term bodge, or will last a substantial period of time. Still I now have a non leaking scoot for the moment, so this gives more time to make decisions about its future.
OT (1) - my Tmax topbox came off a few months ago, and recently its started to come open every time I ride - the lid is bent, and its not fixable. However the workshop guy sold me an elderly but perfectly serviceable Givi big box for £30 which has to be a bargain!
OT (2) - In the workshop today was a Peugeot Satelis 500 - what a superb looking scoot!!!! Its not so much the styling but the beautiful detailing. Sadly anything that wasn't plastic looked rather rotten though....
Re: More troubles
K seal works wonders grumpy
- 2wheelover51
Re: More troubles
It's true, Radweld or similar repairs can last for years. It only needs a pinhole to cause a leak since the radiator's under pressure.
If it was me though I'd keep a bit spare under the seat with some spare coolant, on longer trips...
