The Bern wrote:Globs wrote:Closed coils up also lower the unsprung weight slightly.
How ????????????
Because the more tightly wound end of the spring is heavier.
By placing the lighter end of the spring near the axle the lighter end is being more by the wheel/road, and the heavier end is stationary in the fork leg. In the SYM 300 the closed coils were at the top.
The Bern wrote: ongoing debate with a member who really, really wants to be right in his opinion but simply isn't.
Sorry you feel like that Bern, for me this was a polite discussion about some technical aspects of which I had personal experience of, and somehow you have taken my comments as an attack, that was not and is not intended.
My main points to recap are:
1. Try not to deform the chromed tubes when undoing the top plug, an impact wrench may be safer.
2. Before you pump the oil out check the chrome tubes for any corrosion or defects that stick out, they will damage the seals
3. If you torque the top nut in-situ, only do up the lower pinch bolt first or the top plug may bind in the threads like mine did.
This is also a good situation (on disassembly!) to loosen the top plug, properly clamped in the forks yoke, depending upon access.
This is just friendly advice based on my experience, it's not a criticism but an addendum to The Bern's excellent write-up, I'm sorry if anyone gets offended by this advice but some offence may be better than a damaged fork tube or seal.
Another tip is to use a smaller torque wrench for low NM values, some of the larger ones can be a bit 'heavy' on the low numbers, I have a 3/8ths one just for this reason.
