I'd always thought my jacket was waterproof until I was forced to ride 20+ miles home yesterday in steady rain. Checking back, I find that I've had it 17 years and it's done more than a few miles in all weathers.
Whaddya reckon, chaps - a decent waterproof jacket, armoured elbows, shoulders and back, winter liner? I don't want to spend megabucks, I don't ride as often as I used to/would like, but I want a jacket that'll keep me dry and give protection should the worst happen. I prefer a long-line jacket rather than a blouson-style.
I need a new jacket . . . .
- Current Ride: Honda SH300i
Re: I need a new jacket . . . .
I don't particularly like rst apparel - I've generally opted for dainese in goretex which I find pretty good - not particularly cheap though - apparently tucano urbano gear is quite good
Thanks, Symcity. You're right, Dianese is pricey, unfortunately. I'll have a look at the others, though.
- Current Ride: T-max mk6
Weise gear is well worth looking at - v good quality and not mega bucks.
I've never tested my wet weather gear so much as in the last few weeks of this 'summer' and have concluded that none of my gear is actually that waterproof! There again, most of it keeps you more or less dry for around 20 minutes or so. I think that plastic oversuits, over gloves etc are the only way to really keep dry.
- 2wheelover51
I've got an Alpinestars "Andes" drystar which I've used in constant heavy rain and found to be 100% waterproof. Not expensive either and has removable liner and summer vents. Only downside for me was the sleeves were a little on the longside but they'd probably fit someone of "normal" dimensions! I'd recommend it but not sure how good it would be after 17 years..
I've had a quick look and Weise is definitely on the list, looks good. Thanks Mr G.MrGrumpy wrote:Weise gear is well worth looking at - v good quality and not mega bucks.
2wheelover51 wrote:I've got an Alpinestars "Andes" drystar which I've used in constant heavy rain and found to be 100% waterproof. Not expensive either and has removable liner and summer vents. Only downside for me was the sleeves were a little on the longside but they'd probably fit someone of "normal" dimensions! I'd recommend it but not sure how good it would be after 17 years..
Argh, looks like that one is discontinued! I'll search to see if there's anyone holding stock. Thanks, 2wheel over51.2wheelover51 wrote:I've got an Alpinestars "Andes" drystar which I've used in constant heavy rain and found to be 100% waterproof. Not expensive either and has removable liner and summer vents. Only downside for me was the sleeves were a little on the longside but they'd probably fit someone of "normal" dimensions! I'd recommend it but not sure how good it would be after 17 years..
- horobags
- Waldorf
I wear a Northface kagoul over both my leather and textile jackets.
The textile jacket has a waterproof liner but it's easier to leave it out and put something on the outside. Besides which, it keeps the jacket dry as well as me.
NIU electric moped - HAL
- Waldorf
Sale here:
https://www.sportsbikeshop.co.uk/defaul ... =ML-160717
The e-mail said 'Huge Savings on Dainese'
- Globs
My current fave gear for jackets is Richa.
