Quick Vespa oil change question
- smeghead
Does anyone know if the exhaust needs to come off to change the oil filter please.
- roadster
- Current Ride: Silence S01
Re: Quick Vespa oil change question
Model and year?
SYM Joymax 125 and Honda CB300R. Previously Silence S01, Kymco AK550, Triumph Tiger 850, Triumph Street Twin etc...
- smeghead
GTS 300 2015
Would seriously hope not!
Try YouTube...
Try YouTube...
- smeghead
Good idea!XMax400Paul wrote:Would seriously hope not!
Try YouTube...
- The Bern
No mention of removing the exhaust in the workshop manual bud
Also, you have PM
Also, you have PM
Have wheels, will travel
- Current Ride: Honda SH300i
Remove dipstick - remove oil drain bolt with 17mm spanner - drain oil into a pan - also remove internal plastic filter - remove oil filter with removal tool - no requirement for exhaust removal - lean scooter to the side to get all the oil out - refit drain bolt and the clean plastic filter - renew OEM oil filter - fil with 1300cc of suitable engine oil refit the dipstick - run engine then check level and top up if necessary - fully tighten the dipstick to get an accurate reading or check this video
- smeghead
Thanks Sym, I'll get to and order said filter.Symcity wrote:Remove dipstick - remove oil drain bolt with 17mm spanner - drain oil into a pan - also remove internal plastic filter - remove oil filter with removal tool - no requirement for exhaust removal - lean scooter to the side to get all the oil out - refit drain bolt and the clean plastic filter - renew OEM oil filter - fil with 1300cc of suitable engine oil refit the dipstick - run engine then check level and top up if necessary - fully tighten the dipstick to get an accurate reading or check this video
As said the exhaust does not have to come off. But the filter is still a little awkward to get at so get a filter removal tool. Chain or strap type is best. Again Halfords do a nice chain type for £4.95 that will fit the small size of the GTS.I did mine without the tool but wished I had used one as it's quicker and easier.
- smeghead
I think I can borrow one, if not I'll get one too. Cheers for the info.Data wrote:As said the exhaust does not have to come off. But the filter is still a little awkward to get at so get a filter removal tool. Chain or strap type is best. Again Halfords do a nice chain type for £4.95 that will fit the small size of the GTS.I did mine without the tool but wished I had used one as it's quicker and easier.
