Puncture repair kits
Normsthename
Re: Puncture repair kits
Post by Normsthename »
I ordered the Motorcycle Plugger kit recommended above.
I want it for my bike and also my car that does not have a spare.
I had a puncture in the Twizy a few weeks ago but luckily I had a repair aerosol that did the trick.
I have also bought one of these :-
https://www.amazon.co.uk/Hawk-Cordless- ... s=Air+hawk
The one I bought is the premium version that has a longer lead for £59.99
Just charging the battery, I will report back on its performance :)
1975 Honda GL1000 Goldwing
Normsthename
Tried the cordless tyre inflator and it works a treat!
Checked the pressures on the car, motorcycle and Ebike :D
All of them had low pressures.... :oops:
One of the tyres on the car was 5psi down and it inflated it upto the correct pressure in approx. 30 seconds.
I checked the digital gauge on the cordless inflator with my usual pressure gauge and they were both very close.
The cordless inflator also has a cutoff feature so you set the pressure wanted and press the trigger.
It then switches off when it reaches the set pressure :)
It also comes with a dummy battery that has a 12v accessory plug so you can power it direct off the bikes battery if needed.
It comes in a zipped textile case, it’s a little large for a bike but I will just chuck it in the bike Topbox when I go out for a spin
sad vampire
Current Ride: NC750 DCT+Aprilia Atlantic 500
Post by sad vampire »
I have a cordless Airman under the seat, but I kind of worry about just how much I carry around under there.
Still, I guess that's why we ride maxi scoots.
Steve_D
Post by Steve_D »
Normsthename wrote:...Checked the pressures on the car, motorcycle and Ebike ....All of them had low pressures.... :oops:
Any chance it could be reading low? I always use two tools for inflating my bike tyres - one for inflating and a dedicated pressure gauge just for checking.
Honda SH300i
One tip - don't plug in a 12v pump on a scooter. It will blow the 5A fuse.
Pain in the arse parking bike next to the car in our small narrow road.
StephenC
Current Ride: Kymco DT X360
Post by StephenC »
mottza wrote:One tip - don't plug in a 12v pump on a scooter. It will blow the 5A fuse.
Not on all scooters. But Kawasaki and Yamaha seem to have only a 1a limit, which is pants.
At risk of being accused of being a weirdy Peugeot lover again, none of my 5 Pugs ever blew a fuse powering a 12v pump.
Can is not the same as Should
The Bern
Current Ride: Silverwing 600
Post by The Bern »
StephenC wrote: none of my 5 Pugs ever blew a fuse powering a 12v pump.
Ditto my SilverWing
Have wheels, will travel :D
Must have a 10A fuse
Steve_D
Post by Steve_D »
The slime compressor I bought came with three different power leads - a cigar lighter adaptor lead, a permanent fixed fly lead and a set of leads with crocodile clips that go straight on a battery. Both times I used it, I put the clips direct onto the battery.
Honda SH300i
Normsthename
No, like I said in the post above I checked the pressure with my usual digital pressure gauge and they were both within 1 psi.
The low tyre pressures was just my bad maintenance :oops:
