Anlas Tyres ? 120/80 14
The Bern
Current Ride: Silverwing 600
Re: Anlas Tyres ? 120/80 14
Post by The Bern »
XP500FUN wrote:
A 120/70 14 is 84mm in height compared to a 80 at 96 so will loose abouit 12mm at the front, the speedo difference is negligable.
Firstly, as a general rule reduced sidewall hieght means reduced sidewall flex & as you're looking for a more comfortable ride .....
Secondly, the front tyre aspect ratio will have bugger-all effect on the speedo, SliverWing speedo sensor is on the rear wheel :geek:
Have wheels, will travel :D
Ferret
Current Ride: Aprilia srv 850
Post by Ferret »
I would say diablo rosso has softer shoulders and a harder middle than the standard diablo . I hate Pirelli,s but I am really impressed with the rosso version .
XP500FUN
Post by XP500FUN »
Hi Thanks Ferret, might give one a go, if I can suss out which of the two is more bump absorby, though these do sound really good.
Anyone had one on a Silverwing front at all ?
Thanks Mark.
steve_h80
Current Ride: silverwing 600
Post by steve_h80 »
The difference in rolling diameter might confuse the abs.
The Bern
Post by The Bern »
steve_h80 wrote:The difference in rolling diameter might confuse the abs.
XP500FUN
Post by XP500FUN »
Hi yes good thinking, thank you, so definately going to stay with a 120/80 14 just wish I could find proper info on the Rosso bias diablo scooter, the chap ( very nice and helpful ) at Pirelli Technical in the UK was just reading off the website.
It look as if the angel is what I am after but only P rated, saying that I rarely get over 70 mph these days. 58 load rating though so should be OK.
Has anyone tried a diablo rosso scooter usual trye on a scoot at the front please.
Thanks Mark.
The Bern
Post by The Bern »
What Meldrew (hi bud) says,
Meldrew wrote:Why don't you just buy the tyre
& give it a go, tyres like others things are subjective, for example: I have also had ContiMove 365's fitted on mine at a similar time to Meldrew, his are still 'good to go' where mine are long forgoten, same tyre same machine totally different riding 'style'
The Bern
Post by The Bern »
Ferret wrote:I would say diablo rosso has softer shoulders and a harder middle than the standard diablo .
Presumably because Diablo Rosso are dual compound ?
Current Ride: T-max mk6
Meldrew wrote:Why don't you just buy the tyre.
Well, that's OK if you are talking about a well known brand, which you think should be OK (but not always....) but amongst the lesser known brands, there's some real crap out there eg Vee Rubber, IRC and its the point of the forum to share info to avoid expensive wastes of money.
XP500FUN
Post by XP500FUN »
Hi I`m choosing carefully this time.
The last one a Michelin SC pure was OK in the dry but not the wet, also it squared off badly, worst I`ve ever had and I kept on the pressures etc. Also they have the wierdest groove following going on etc. Can be really nasty.
The pirelli`s look good but quite new so very hard to find any advice etc.
They tend to last 9/10K on the front so will be there for a while so want to get it right this time.
At least getting the front out/in is nice and simple.
Best Mark.
PS I`v had a mixed bag with Pirelli`s in the past on bikes but these Diablo rosso scooters do seem to have had a lot of effort put in.
The not so greatness of the SC pure michelin has surprised me. Though in the dry very good. But I suppose most tyres manage that usually.
