Seized handlebar holder
tgeorgeson
Current Ride: Xmax 125
England
Post by tgeorgeson » Wed Aug 07, 2019 4:51 am
Hi all,
Someone attempted to break a steering lock on my xmax 125. All they seem to have done is de-aligned the handlebar holder. But they also seem to have made it pretty stuck.
The fork seems fine - but I just can't seem to re-align the steering head (number 3) at all. I've tried wd40 and holding the front wheel with my legs. I took the woodruff key out before trying.
Any ideas? I was considering using a blowtorch on the handlebar holder to see if that would help - but might end up causing some damage to the surrounding area.
Current Ride: XMax400 - SH125
England
Re: Seized handlebar holder
Post by SH125Paul » Wed Aug 07, 2019 6:46 am
cant see any pics that the No 3 may indicate...
If I remember when the XMax400 went in for head bearing work...
The holder is on a taper, with woodfruf key as you mentioned...
Does that look sound right?
Tri a puller on it to get it off then re align and tighten down - rather than trying to twist...
Workshop had a 'mare getting mine off - well presume they eventually got it off...
tgeorgeson
England
Post by tgeorgeson » Wed Aug 07, 2019 10:09 am
Yes - the same issue, cheers.
Maybe I can fashion a puller from some other tools. If not, I'll see if a workshop has something.
Blowtorch is a last resort. It normally works when two metallic materials get stuck together.
Thanks!
Maxster
Current Ride: None
England
Post by Maxster » Wed Aug 07, 2019 10:20 am
If you can get it to a decent friendly fabricator they'll get it off in 10 seconds,
roadster
Current Ride: Kymco AK550
Saint-Martin (French part)
Post by roadster » Thu Aug 08, 2019 4:20 am
If its aluminium alloy then heat would definitely do the trick, and maybe not as much heat as you might think so you might start of with boiling water. If possible leave the top nut loosely in place because a taper is likely to release abruptly and do you or the scooter some damage.
Rides Kymco AK550 previously Kymco Downtown 300i ABS and Triumph Street Twin.
England
Post by SH125Paul » Thu Aug 08, 2019 4:37 am
think they ended up with a twin leg puller...
I have a draper puller can be converted from 3 to 2 legs etc...
duct tape around the bars etc before fitting the puller to avoid marking....
As mentioned may go abruptly - so pack around the area with rag to avoid damage and scratches to surrounding plastics / screen etc
tgeorgeson
England
Post by tgeorgeson » Sat Aug 10, 2019 2:42 pm
Cheers. Couldn't find an angle with the 3 leg, so going to try again after ordering a 2 leg.
Thanks for the advice on the nut etc.
tgeorgeson
England
Post by tgeorgeson » Sat Aug 10, 2019 7:14 pm
Just pour it on? Worth a try. Heat onto the handlebar holder than the thread (tube/fork header)?
England
Post by SH125Paul » Mon Aug 12, 2019 5:37 am
Wrap the holder in rag...
Then slowly pour on boiling water from the kettle...
That way the water wont go every wear and localised heat may help...
If the centre nut is undone - try bolting the bars back in the holder - something to waggle on when trying to free off...
