Eh...I'm getting sick & tired of this scooter lark - it seems an acheivement to go for more than a week without some reliability issue!
Latest snag is that the Bev is loosing all its coolant. As soon as I got the Tmax back from its radiator troubles, I was on the Bev and noticed the temp gauge was high and the cooling fan was on (very rare occurrence). I happened to be near the workshop, so called in but it then seemed Ok, --- they put some coolant in (quite a lot actually) and then everything was fine. Now I've got the same thing and if I top up the coollant, you can hear it draining down to the depths of the radiator - ie there's probably no coolant at all!
I'm not seeing ANY leaks or driibbles or damp patches under the scoot, so it must be being pumped out when the engine's running somewhere. Another trip to the workshop.....
More troubles
- Current Ride: T-max mk6
- Globs
Re: More troubles
Not good
It must be going somewhere, any marks of dried coolant anywhere?
Is the oil clear?
Does the inside of the exhaust look normal?
Is the oil clear?
Re: More troubles
Seems weird that both have similar issues...
- 2wheelover51
Re: More troubles
You've certainly had a few problems recently. Sounds like head gasket or a surreptitious leak somewhere.
Re: More troubles
Nothing obvious. What worries me is that its either something easy like a leaky pipe or joint, or something very expensive, like head gasket, water pump, radiator. If one of the latter, could be too expensive to be worth fixing! On the bright side, I just topped it up, and its only lost half its coolant, rather than all of it!
Re: More troubles
They used some very silly one fit hose clips, good idea to look around them and replace dodgy ones with better quality ones.
Honda Wave 110i
Honda Wave 110i
Re: More troubles
I don't think you and that Scooter were meant for each other, if it were me I'd "Give it a damn good thrashing" and if it still misbehaved, I'd get rid.
Re: More troubles
I've had it for quite a long time now...I haven't had many major problems, but a series of little weird things! It was my commuter scooter, but I don't actually need such a thing anymore. Therefore I don't really want to replace it, but with the Tmax playing silly buggers a lot, its nice to have a back up scoot when needed!Sylar wrote:I don't think you and that Scooter were meant for each other.
Re: More troubles
Well, I must have seriously offended the scootering Gods!
Diagnosis of the Bev's water coolant leak is that its coming from the cylinder barrel, not at the head gasket end, but the lower end, probably due to corrosion. The leaking water is then hitting the exhaust or other hot parts of the engine and boiling away (not going into the oil). Snag is of course that a new cylinder barrel effectively means a complete engine rebuild which would cost £x00, and probably more than the scoot is worth! Put bluntly, its knackered.
No idea how to proceed at the moment. At the moment, its running fine, and adding a few quids worth of antifreeze & water every few weeks will keep it mobile, but of course, the leak will get worse not better. Workshop did say you could try something like Radweld - it probably won't work, but if it doesn't you've only wasted a few quid. They also say I should trade it in for something (ie without telling dealer its knackered), but I'm too honest for that! Anyway, its only probably worth a grand tops as a PX even if it was fine.
As I've said before, I don't really NEED a second scoot, but one is very handy to minimise the mileage on the Tmax, keeping it from too much salt exposure, and having something handy in case the other one fails!
Any ideas? Anyone wants a Bev project to hone their engine building skills???
- horobags
Re: More troubles
there must be someone able to do a repair, assuming its not near the bore, still not a simple job but as it is with the leak its value will be slashed.
