Actually they see you coming and put up the `closed for refurbishment` signs...Dave Weller wrote:The S-wing 125 has a range of 200 miles, it uses fuel at a rate of 90-120 mpg.
The Burgman 650 has a range of 180, it uses fuel at 45-60 mpg.
So looking at those facts, if I use the 125, I get twice the distance for my money, but because of the smaller tank size I can travel little more between fill ups.
My CB250 has a 14 litre tank and can easy do 300 miles on a tank full which would be be same as my old Pan-Europeans on their 28 litre tanks.
If I'm touring I like to always have at least 100 miles left in the tank, you never know if the next garage is open (many times they have been closed for building works or gone out of business when I arrive).
Tank range
- irev
- Current Ride: AN400
Re: Tank range
Sylar
Re: Tank range
I recently did a fuel check on my Silverwing 600. Starting with fuel visible in the filler neck, full. I took a 2ltre container with fuel in it and ran till i was empty. 221 mls on 16 litres.
- Drago
- Current Ride: SYM Mask 125
Re: Tank range
At average A-road speeds My GTS does 217-225miles until I hit reserve.
Best I ever got was 230 miles. I always reset my tripometer with each refill.
I always brim it when filling. Usually fill up with 11-11.5 litres with 350-370km
on the tripometer.
My Tonik can only do around 100-110miles before it needs refilling.
on the tripometer.
Current rides
SYM Joymax Z+ 300 2022+
SYM Mask 125 2019-
SYM Mask 125 2019-
- bornagainbiker
Re: Tank range
Burgman 650. My last bar starts to flash at about 140-145 miles and filling from that point takes about 11-11.5 litres with about 3.5-4 litres (just under a gallon) left, so I think about 190 miles would be my maximum. Just got my best mpg yesterday on a long 150 mile country road run at 58.6, would be nice to get more but it is a big twin.
- Zed
- Current Ride: Trek 7300
Re: Tank range
Mine does about 60 miles before the light comes on...
Re: Tank range
That's pretty good for a Silver Wing I suspect. You may know this so apologies in advance if you do. Bear in mind it isn't good to run her dry as the fuel pump gets very very hot when you do that and can lead to early failure of the pump. They normally cost a small fortune to replace.Sylar wrote:I recently did a fuel check on my Silverwing 600. Starting with fuel visible in the filler neck, full. I took a 2ltre container with fuel in it and ran till i was empty. 221 mls on 16 litres.
barryG
Re: Tank range
I tend to fill up around 170 to 180 mile after filling up, it will go further though.
- StephenC
- Current Ride: Kymco DT X360
Re: Tank range
Zed wrote:Mine does about 60 miles before the light comes on...
Yes I remember on the A12 you could barely make it between petrol stations!
The Sat250 gets about 185miles before the light comes on. Takes just under 10 litres to refill. Holidng my nerve I have stretched it to over 200miles a couple of times.
Can is not the same as Should
Sylar
Re: Tank range
You are quite right Data, i would agree with you . It was a one off, as purely a mileage/fuel check
mdk1
- Current Ride: Suzuki Burgman 400
Re: Tank range
The GP i could just about manage 200miles whilst having sum fun. think it was a 16ltr tank.
The Matrix, is still to new to work out really, but it only hold around 5ltrs, so should give me around 110miles when it's run in.
Mike,
Suzuki Burgman 400.
Gone, Honda Forza 300 Sinnis Matrix 2, Gilera GP 800, Piaggio Zip 50
Suzuki Burgman 400.
