macp wrote:First off take it easy buddyirev wrote:Moreover, whoever gave you that advice should show you their research and development credentials.
It's the kind of pathetic back-of-cornflakes-packet guidance from somebody who should be eating Farleys Rusks... take it, and die.
Clear?it was only a question following a thread I was reading where an owner fitted a pair off michelin pilot sports to his aprilia scoot with a different profile and in his opinion it improved the ride. I was curious to read if anyone else had tried it and what they thought. At no time did I say anywhere in my post that I was going to do this although re reading my post I guess it came across that way.It certainly wasnt my intention to pee people off.
Not setting me off, simply telling you exactly how it is.
As an ex R&D person whose job was to test precisely these things I could tell you how dangerous it is for small-wheeled vehicles to change tyre sizes on the existing rims (disproportionate difference in rolling radii and contact footprint compared even to larger-wheeled bikes) but there's really no need when you can summarise the issues as easily as `Do it and Die`.
BTW car analogy doesn't apply as the geometry of steering and suspension do not significantly alter by changing rolling radius, nor does the steering moment arm significantly alter when wider tyres are used. It's this that give ideas to fuckwits in the PTW community that it ought to be a good idea for bikes).
Your eggspurt is more than welcome to come here and justify his arguments to save embarrassment.
Yours, not his as there's more than enough expertise here to rip `im a new one, if he even turns up. And if he doesn't, then clearly he's not prepared to back up kitchen-table advice that risks someone elses life. And that makes him a lying arsehole on top of incompetent cretin. I suggest he runs for office as he's fuck all use for anything else.
One additional point that does have relevance to the discussion and does muddy the waters - stated tyre sizes are nominal only and are not supported by regulatory requirement for validation. You can put a range of nominally same-sized tyres alongside each other and be utterly amazed at the range of size and shape differences.
Diameter, rolling radius, shoulder shape and width, proportion of rim width to shoulder, in fact every single measurement can drastically differ between same-sized tyres. It's the principle reason recommendations are always based on matched pairs front-and-rear.
In that situation there MAY be some advantage to mixing'n'matching - hence the notion that varyng a 190 and 200-rear can result in easier turn-in - but it may not be because of the nominal width decrease it can simply be that the profile is more favourable for the front. I have even seen 180 tyres that are actually across the shoulder wider than 200's...
Although again, it could just as easily kill you.
And lest anyone thinks I overstate the case, I've given expert witness testimony at Coroners Inquests over this. Hence no mincing of words.
