when you go over 15% less weight you will prob end up with too much clutch slip and heat build up of clutch shoes from expierienceFerret wrote:If you just want to pep it up a little then standard weight - 10% should be enough unless you want big improvements in acceleration at the cost of top end speed .
Polini Maxi Hi-Speed variator
Re: Polini Maxi Hi-Speed variator
beespeed confirm roller size http://www.beedspeed.com/html-pages/var ... -chart.htm" onclick="window.open(this.href);return false;Brimma wrote:Thanks for the help so far
Have had a look on the Dr Pulleys website, and have concluded that the Runner needs 21 x 17s for the 200 engine
Standards appear to be 10.7g, so I presume I'd need something like 9.5g to make a worthwhile difference
Is anyone prepared to stick their neck out and confirm whether or not I've got that right?
21x17 10,7 gms x 6
- Brimma
- Current Ride: Forza NSS300
Thanks, Michael, I'm impressed that I managed to get that right
Looks like America might be the best option
http://www.ebay.com/itm/DR-PULLEY-ROLLE ... ORE:US:101" onclick="window.open(this.href);return false;
i used scooter assasins a month ago and they got the dr pulleys in for me as they did not have in stock then delivered in a week, better price than germany and dr pulleys are from taiwan where scooter assasins are based i thought you wanted to go slightly lighter say 9.5 gms if so these are the ones from same seller http://www.ebay.com/itm/DR-PULLEY-ROLLE ... 5d4508aff8" onclick="window.open(this.href);return false;Brimma wrote:Thanks, Michael, I'm impressed that I managed to get that right
- Brimma
Orderedmichaelphillips wrote: i used scooter assasins a month ago and they got the dr pulleys in for me as they did not have in stock then delivered in a week, better price than germany and dr pulleys are from taiwan where scooter assasins are based i thought you wanted to go slightly lighter say 9.5 gms if so these are the ones from same seller http://www.ebay.com/itm/DR-PULLEY-ROLLE ... 5d4508aff8" onclick="window.open(this.href);return false;
Thanks, Michael
i presume you have taken off a variator beforeBrimma wrote:Orderedmichaelphillips wrote: i used scooter assasins a month ago and they got the dr pulleys in for me as they did not have in stock then delivered in a week, better price than germany and dr pulleys are from taiwan where scooter assasins are based i thought you wanted to go slightly lighter say 9.5 gms if so these are the ones from same seller http://www.ebay.com/itm/DR-PULLEY-ROLLE ... 5d4508aff8" onclick="window.open(this.href);return false;
Thanks, Michael
ps i always ring them to see if variator tool in stock before ordering as they tend to dropship instead of holding parts
http://www.dropdedpeds.co.uk/auto-scoot ... 18640/470/" onclick="window.open(this.href);return false;
http://www.psntuning.co.uk/scooter_parts.php?prt_id=890" onclick="window.open(this.href);return false;
http://www.ebay.co.uk/itm/GILERA-RUNNER ... 43be97e67d" onclick="window.open(this.href);return false;
- Brimma
No I haven't actually, I've never owned one before this one, but many thanks for the linksmichaelphillips wrote: i presume you have taken off a variator beforejust make sure you get it back on very tight... dont know off hand the torque number, as you dont want it to come off.. there is a variator holding tool by buzzetti you can do a search for VS18640 there about £15 but if you can get away with an airgun then you will be ok the nut should be ok as not that old, they say to replace every time its off but not necessary , anyways two links here , one for the holding tool which makes the job a lot easier and one for the nut
ps i always ring them to see if variator tool in stock before ordering as they tend to dropship instead of holding parts![]()
I was going to get a quote from a local independent, they'll probably do it in a fraction of the time it would take me, and have the proper tools for the job
yes a good independant that you can trust and use for future is a safe bet, the dr pulleys go in a certain way so have a good look at pics etc on net as they are shaped and the independant might have never fitted these before as they sling in round rollers usuallyBrimma wrote:No I haven't actually, I've never owned one before this one, but many thanks for the linksmichaelphillips wrote: i presume you have taken off a variator beforejust make sure you get it back on very tight... dont know off hand the torque number, as you dont want it to come off.. there is a variator holding tool by buzzetti you can do a search for VS18640 there about £15 but if you can get away with an airgun then you will be ok the nut should be ok as not that old, they say to replace every time its off but not necessary , anyways two links here , one for the holding tool which makes the job a lot easier and one for the nut
- Brimma
30 mins labour to fit.......£21 inc VAT at local Ducati dealer
Would be silly to buy the tool for £14 and do it myself really
Can't wait for their arrival to see how much difference they make, should be quite noticeable from the reviews I've read
- poldark
+1michaelphillips wrote:brisk spark plugs and a sports air filter... dr pulleys and a polini contra spring and thats it your sortedMjW wrote:Don't say that! lolFunkycowie wrote:The only way you'll increase it after Dr Pulleys with any real noticeable difference will be a with a turbo fitted
I was planning to fit those nice "racing" spark plugs everyone is raving about in the other thread and a j-costa or malossi variator next year. If it is as you say maybe I should just fit the spark plugs and start considering a street triple or something more retro/cafe racer.
On the move with Tapatalk
