T Max 530 Mk 4 symptoms of a worn rear drive belt?
- tmaxrobbo
Re: T Max 530 Mk 4 symptoms of a worn rear drive belt?
So , I removed the belt cover and the belt looks fine, correct tension and no wear . Fair bit of dust which I cleaned out . Put it back together, and listened with a stethoscope, no noise from the belt , but the little chirp remains. I can hear it when I close the throttle and the bike is slowing down . It persists after I brake with the bike on the centre stand and the wheel has stopped turning . It seems to be coming either from the akrapovic (quiter when I put a rag over the pipe ) or from within the engine, almost could be like an alternator bearing. It's weird, when new I used to hear the belt whine at about 30mph, as it was new , but that's faded as it's been used more or less everyday for 3 years . Maybe now it is becoming a money pit !!
- tmaxrobbo
Update. Passed its MOT yesterday with advisory re noisy exhaust ( akrapovic) otherwise nothing. The belt is clearly fine and the chirp comes and goes . Rides great just get the weird noise coming to a stop, nothing horrible just a new noise. Driving me mad
Chocky
- Current Ride: Tmax 560 Mk8
I agree that the noise is annoying. I had the same sound coming from my belt, albeit at 27,000 miles, which I replaced and the noise went. The problem may be the alignment of the back wheel.
The belt seems to be a sandwich of rubber with a steel band in the middle. I suspect what happens is that if the toothed wheel alignment at the back wheel causes the belt to rub against the raised side of the toothed wheel, the rubber coating on the side of the belt wears away, exposing the edge of the steel band. I am sure that it is this which causes the noise.
You could check to see the running position of the belt on the toothed wheel to see if it is rubbing against the side and check the alignment of the back wheel. If the alignment is OK, I would find out whether it is allowable to turn the belt around (this did not occur to me at the time). As to the noise just happening on a closed throttle, it could be that the belt moves across the toothed wheel to one side on a closed throttle.
- tmaxrobbo
Thanks Chocky , I think you are right. Looking closely at the belt, there are tiny bits of fraying at the side, the belt itself is otherwise fine insofar as the ribs are all intact. It rides fine but I will change the belt at the next service when I'll put new tyres on as well.cheers
Pukmeister
What about a squirt of teflon dry lube on the belt/pulley ?
A lot cheaper than a new belt, might be an interim fix ??
Symcity
- Current Ride: Honda SH300i
I’m assuming this includes labour to fit the belt - polini belt around £100MrGrumpy wrote:The temptation is to try a new one, but at £240 a go, maybe its best to grimace and bear it
http://www.pedparts.co.uk/product/4396/ ... a-tmax-530
- Greyerbeard
As it says on the advert...!Symcity wrote:I’m assuming this includes labour to fit the belt - polini belt around £100MrGrumpy wrote:The temptation is to try a new one, but at £240 a go, maybe its best to grimace and bear it
*This is the belt for the variator and NOT the rear wheel drive belt.
1964 Matchless G3
1989 Honda C90
1998 Honda CB250 Nighthawk
2025 Honda ADV 350
1989 Honda C90
2025 Honda ADV 350
Symcity
I’ll no be getting a tmax then
- tmaxrobbo
will give that a go cheersPukmeister wrote:What about a squirt of teflon dry lube on the belt/pulley ?
- The Bern
I've probably got the wrong end of the stick here but, I thought that the drive belt worked by friction, surely lubricting it &/or the drive surfaces would cause slippagetmaxrobbo wrote:will give that a go cheersPukmeister wrote:What about a squirt of teflon dry lube on the belt/pulley ?
Have wheels, will travel
