That's where the switch is for my heated grips. Looks quite smart.Snail wrote: Still got to put an extra USB sochet on and leaning towards a flush fit one in the plastic next to the glove box, as this is easily removed to gain access and plenty Of room behind it wired to ignition switch?
Sat Nav/Phone holder
rayb
- Current Ride: Honda SH300
Re: Sat Nav/Phone holder
Snail
- Current Ride: Burgman
Morning Ray, where did you connect the live and earth to on the ignition switch, going to use 5amp in line fuse, I haven't looked yet too cold!
Might brave it after lunch i have a wood burner in the garage which I made out of an old gas bottle,
My son works for a worktop maker so brings loads of hardwood offcuts home for me
rayb
I pulled back the boot on the ignition switch and soldered the live to the switched +. Bolted the earth to the horn bracket.
Snail
Finally got round to fitting my usb socket! Single switched outlet flush fit with rubber cover to keep the rain off?
rayb
Exactly where the switch for my heated grips is. That certainly is a "Head-up" display snail.
Snail
Yes suits me sir! Very little eye time off the road ahead! Plus the wife can look over me shoulder and still drive from the back seat!!!
rayb
I like my USB socket being on the handlebars. The connecting lead is on 25cm and goes with the turns.
