T max mk 6 heated grips have gone from menu ?
tmaxrobbo
Re: T max mk 6 heated grips have gone from menu ?
Post by tmaxrobbo »
MrGrumpy wrote: Tue Oct 02, 2018 1:16 pm OK....but what happens if it fails again in just over a year's time???
Then it will get oxford Grips . Once out of warranty I could not justify the coat to fix , and the oxford grips are fairly easy to fit . I like the idea of factory fitted grips but they are never going to last forever :|
I've got the Oxford Scooter grips...just a simple on / off switch and no scrolling through menus at 70mph!! There again, had a slight oversight in that we mounted the switch rather too low and out of sight, meaning its a bit of a search finding it!
Do you know exactly what went wrong the Yam grips? If the new set of grips fails again, If the actual heating bit is still working, maybe a clever person could connect the functioning grips to a simple switch. Of course, if the grips themselves are buggered then you'd have to replace the whole kit!
tmaxrobbo
Post by tmaxrobbo »
MrGrumpy wrote: Wed Oct 03, 2018 8:20 pm I've got the Oxford Scooter grips...just a simple on / off switch and no scrolling through menus at 70mph!! There again, had a slight oversight in that we mounted the switch rather too low and out of sight, meaning its a bit of a search finding it!
its going in tomorrow so will find out Cheers
tmaxrobbo
Post by tmaxrobbo »
So the right grip had a snapped wire , causing the computer to delete the grips . Wires were too short , now corrected on the new grips. Nice and warm again ready for winter. Had a nice demonstrator T Max while they did the work only 67 miles on the clock and much tighter than mine which has done 5000 miles. These bikes get better with age 😎
Pukmeister
Post by Pukmeister »
One of my first tasks was to winterise my Mk 3 including shad muffs, tucano urbano gaucho and oxford heated grips.
The Oxford grips I bought are superb: easy to fit wiring as they go straight across the battery, auto shut off if the bike stops so no flat battery. Very quick to heat up and powerful, I never need more than medium heat.
Glad your Mk6 is sorted and I hope the replacement Yamaha grips last.
Scootypuff snr
Post by Scootypuff snr »
tmaxrobbo wrote: Sat Oct 06, 2018 12:36 am So the right grip had a snapped wire , causing the computer to delete the grips .
penny pinching aside (ask suzuki about wiring loom recalls) is deleting a programme over a damaged wire a good thing so preventing battery drain?
tmaxrobbo
Post by tmaxrobbo »
Scootypuff snr wrote: Sat Oct 06, 2018 10:45 pm
Not sure , normally the left should have kept working . If these fail I will fit oxford grips , the Yamaha ones are noy that hot , but take the edge off
Scootypuff snr
tmaxrobbo wrote: Sun Oct 07, 2018 12:48 pm
strangely not unique to yamaha, Honda oem heated grips better slated on all forums but as they came standard I accepted them and like you will change to oxford in the event of failure.
tmaxrobbo
Post by tmaxrobbo »
Gone again after 6 months . Still under warranty but I feel some oxford grips coming on. Do they need to be turned off or stop when the bike is turned off ?
tmaxrobbo wrote: Wed Feb 20, 2019 11:19 pm Gone again after 6 months . Still under warranty but I feel some oxford grips coming on. Do they need to be turned off or stop when the bike is turned off ?
They are wired into the battery, but there is supposed to be a clever feature that detects current flow or something and turns them off if the engine is off. Can't say I'm keen to put it to the test!
