drive belt snapped
Re: drive belt snapped
Be okay or brake cleaner might be bit better .Check operation of clutch pulley twist and pull or push if got it off on floor .
MT606
Current Ride: burgman 400 c90
Post by MT606 »
wilco... just got the replacement belt, is it supposed to be showing the cord?
Yes goes all way through it .
MT606
Post by MT606 »
I know I pulled the remnants of the old one off the rear pulley yesterday ;-) but thought it shouldn't be showing on a brand new one?
From what I understand they aren't made individually they make a big roll then cut belts from that .
MT606
Post by MT606 »
ah....
Ralph
Post by Ralph »
If it's not stuck on to firm how about one of those air duster computer cleaners,
brake cleaner may be good but be sure to lube anything that needs it as it will
be degreased, and keep all of it away from the belt and the bits it runs on.
Ralph
Nr Fleetwood
MT606
Post by MT606 »
will do, I finally got the drive pulley off what a fuck about! had to borrow a hammer drill thingymabob from the bike shop to do it! took the thing apart afterwards to check the rollers, they were knackered aswell so ordered a replacement set from wemoto, will put it all back together in the week.
When put it back make sure have slack in belt before final tighten .You can squeeze belt together to get it down in rear pulley that creates enough slack in front pulley so you don't pinch the belt .Otherwise its not as tight as you think once belt realise its self .
MT606
Post by MT606 »
I could only get the belt 5mm if that under the lip of the rear pulley, how will I know if its pinched it/not tight after I've put it together n run it? will it not accelerate well or loose top end umph?
