kishan wrote:fitted led tail light and led white side light bulb and metal dustcaps ha ha
metal dust caps, are best fitted with a finger smear of grease around the valve thread, that way they dont seize in place :)
just saying as one muppet did not have the same experience, in a thread not long ago... thats if some kid does not nick them ;)
Scootles
Current Ride: Vespa GTS 300
Post by Scootles »
Mounted a luggage rack and top box. Also mounted the controller for my heated grips. To do this I ordered a second hand handlebar cover from eBay as I needed to fit a bracket and didn't want to drill my nice new plastics. It is a slightly untidy bit of plastic, but in this case it's function before style.
All set up for my Europe trip in June.
Cookie
Current Ride: SilverWing - PCX - C90
Post by Cookie »
Meldrew wrote:What's with the blowtorches? All you need is one of the gas burners on your cooker and a pair of needle nose pliers to hold the washer.
Yeah, good point Meldrew but I've got an electric cooker - not that it gets used a lot for cooking. It's last major use was getting the main bearings out of an Enfield crankcase - just fitted in the oven a treat! :D
as long as you take the caps off regularly to check tyre pressures you should be ok
havnt done it yet but I have to ride in the rain
spent hours last week cleaning the bike and it will get dirty :( :(
Cookie
Post by Cookie »
Those metal dust caps that also act as valve extractors have been around for decades and I can't ever remember one seizing in place.
The Bern
Current Ride: Silverwing 600
Post by The Bern »
The metal dust caps that also act as valve extractors are made of brass, brass nut on a brass stem is fine, the ones that can seize are the nice shiny aluminium ones, aluminium nut on a brass stem can have a bi-metal reaction when whetted with water hence the need for a grease "barrier"
Have wheels, will travel :D
Cookie
Post by Cookie »
Yeah, good point Bern, hadn't thought of that.
Globs
Current Ride: Piaggio X10 350
Post by Globs »
Just think of an early Lotus engine, lots of dissimilar metals sitting in fluid setting up some interesting chemistry ;)
Globs
Post by Globs »
I always run black plastic caps, they are lighter and therefore stress the valve stems less when going at huge speeds..
