I went to jesters a couple of years ago, great show, lots there.pikey wrote:Off to Jesters scooter fest Sunday at Leek
- horobags
Still no Dr Pulley bits... hopefully they will come tomorrow morning when I have the scoot in bits to do the other stuff... if not I will have to take her apart again next weekendFunkycowie wrote:Still waiting for Dr Pulley sliding rollers and sliders
I think I enjoy the puzzle as much as riding
No Dr Pulleys...
Sprint Air Filter installed, Brisk plugs installed, coolant drained and refilled, engine started to warm up the oil and its now draining whilst I have my lunch
Changed fork oil seals and oil. Then a service. Since my tomtom rider stopped working got a ultimate add ons waterproof case for my s5. So I now have sat nav. Adjusted the change. Ordered some caliper bolts so will fit them before we go Saturday
Oil filled, topped up the coolant, ran the scoot, let it cool a bit then checked the oil level, topped up a tad.
And then rode it like I stole it.... god I have missed Brisk Plugs and the Sprint filter helps some too I think... now if only the Dr Pulleys had come too!
- kishan
gave my runner125 alittle wash today
- Globs
In a bid to remove the harshness of my SYM GTS300 (Voyager/Legrande) front forks under braking I'd taken them off a little while ago for re-oiling.
These are known for being unevenly filled and having too little oil.
So today I emptied the forks of the old dirty oil (had to use an impact driver to get the tops off), twice flushed/pumped with with new oil and refilled with 107cc of Yamalube 10W fork oil. Also flattened a couple of little bumps on the chrome so my seals last.
Just under 100cc came out and I got the 107cc spec. from a French SYM forum, so it made sense to go with that.
After filling they had even oil levels of 230mm (spring in, fully extended, cap off), instead of the 245mm and 260mm before the change. This should reduce dive (less air space) and the new quality oil will work better anyway.
Ready to refit and torque up.
went to Big Dens and picked up the big Burger, number four..
Muchograssyarse Den and Ian was most impressed with your stable.
Said " what a nice man "
Cheers and thanks again..
now to start on it nothing wrong folks and as always with bikes from Den
it IS as stated...but you no me
so what to do first!
a mug of tea in the morning and have a sit down with pen and paper and have a good stare at the new baby:)kayz1 wrote:went to Big Dens and picked up the big Burger, number four..
Muchograssyarse Den and Ian was most impressed with your stable.![]()
Said " what a nice man "![]()
it IS as stated...but you no meso what to do first!
That's what I do... except its coffee and I am working on the design
