Checked tyre pressures and gave her a wipe down for the Pie and Mash ride tomorrow
Funkycowie wrote:Tmax belts will still look new after 12000 miles of use, did you measure it?
There's only a 1.5mm tolerance, 32mm fresh, down to 30.5mm limit.
It's the across the width Steve.StevenM wrote:will check again this week, I'm off all week. am I measuring from the top teeth to the bottom teeth
Thanks matebornagainbiker wrote:It's the across the width Steve.StevenM wrote:will check again this week, I'm off all week. am I measuring from the top teeth to the bottom teeth
