Deleted User 796
Post by Deleted User 796 »
Put in some led side lights from Halfrauds to match the new led headlight.
Saves about 40 watts total so should have a happy battery when all the heated clobber starts getting used.
i love the LED light system on the pcx the total is around 5 watts to run them all and the headlight is what i would term as life saving, you might think that is a strong thing to say, yet i think all new scoots and bikes should have them nowadays, its amazing when riding in day or night how many cars defo see you where they may have not :)
24000 mile oil and filter change and yet another set of rear pads with yet another new connector gasket in the exhaust.
gn2 wrote:24000 mile oil and filter change and yet another set of rear pads with yet another new connector gasket in the exhaust.
have you done this yoursen now, as was not sure when your warranty was up :kiss: the final drive gearbox is a two year change :D just mentioning as i was trying to find the valve check intervals in the owners manual (just thought id have a ganders) i saw you mention doing yoursen / out of warranty
Yep warranty has expired now.
Couldn't find my syringe, so will need to search the shed.
Valve check interval on the Forza 300 is 16000 miles, the PCX is 2500
Cookie
Current Ride: SilverWing - PCX - C90
Post by Cookie »
Yes, that 2,500 interval for the valves on a PCX is a pain. I've always left mine considerably longer than that and they've been in spec. It wouldn't be such a problem if you didn't have to do so much dismantling to get to them.
gn2 wrote:Yep warranty has expired now.
thanks for that info 8-)
Cookie wrote:Yes, that 2,500 interval for the valves on a PCX is a pain. I've always left mine considerably longer than that and they've been in spec. It wouldn't be such a problem if you didn't have to do so much dismantling to get to them.
well at least they are valves, never done shims and i suppose you would have to have the different sizes u need to do them, (could be wrong as not needed to research shim type) you can hear close up if the tappets are too far out, i will check at 2500 mls yet i cant see them needing to be done till 5000 miles at least, like the manual says, inspect... i suppose the garage would do a sound check and not a visual :lol: :lol: so on that basis, use your own judgement
ive only done 615 miles so far :shock: :shock: so prob might not have the scoot when it gets to 5000 miles, as thats 4 years ish away :lol: :lol:
not had a good ganders underneath the engine to inspect whether the access, on a bench could not be made bigger to get the valve cover off, and do it that way, even if neat cutting the under belly pan, then rebolt that piece could be a way :D
Mmm shim under bucket
measuring is one thing, doing anything about it is another...
The Xmax 400 is shim under bucket - due at 24,000 miles...
Had an FZR1000 Exup Cylinder head - Genesis - 5 valves per cylinder... was never brave enough...
screw n locknut is enough of a faff for me...
Mmm shim under bucket.... likewise paul... it put me off when i saw a utube of a guy doing it, and the shims looked like different thickness 2 pence pieces :shock: so you would need a few :lol:
