Z750Jay
- Current Ride: Vstrom 1000
Looked outside, hmmmmm -4'c and dark, ah the joys of winter riding
- muddyfox
Z750Jay Looked outside, hmmmmm -4'c and dark, ah the joys of winter riding
Me. Looked outside, hmmmmm -4c and dark, coffee and back to bed ah the joys of retirement.
Muddyfox (Nottingham)
Ride safe
Ride safe
Redvision95
- Current Ride: Elyseo 125
Popped my head out the window. Too cold to be riding this morning. Ill wait until around lunch time for it to warm up to go and get my biscuits. Got some work lined up in the morning so I have to be up and riding for that
but atleast I can avoid it this morning
Z750Jay
Soooooo envious. Only another 19 years to gomuddyfox wrote:Z750Jay Looked outside, hmmmmm -4'c and dark, ah the joys of winter riding
Redvision95
Scootles
- Current Ride: Vespa GTS 300
Believe me, when you get there you'll wish you were 19 years younger.
Z750Jay
Gave the Burg a quick wash to get rid of the road salt ready to tart up with Xmas dec's for tomorrow's Toy Ride. Very very quick wash mind you as I normally do not do that cleaning thing, just wanted to get rid of the white salt streaks on a black bike
Redvision95
was out on the Elyseo all morning. Not a single problem. Performed well.
Came to pull out of Asda car park after getting some lunch and she cuts out, refuses to start back up. Pushed her the 10 minutes home. Then she started to leak fuel! half a tank on the floor later, we syphoned the remaining fuel out of the tank and left her in the passageway half stripped down. I think its either the petcock or the float sticking open, im going to fit a manual fuel tap anyway and take the carb off to clean it up. Hopefully that fixes the leaking fuel issue.
May have to buy a whole CDI + Ignition kit from Peugeot, Only clicks when the starter is pressed so its one of three things. The CDI has gone (immobiliser type so whole lot would have to be changed), The relay has gone or the starter itself has packed in.
Either way, shes going to be parked up for a few weeks. Gives me some time to fit 12v socket + do repairs to glovebox and put the fan on a switch etc anyway.
I would first off check the battery voltage...." IF " that is OK check the solenoid if that is ok check the starter motor. Pugs bike and car have the magnets glued to the outer case and they DO fall off...I have just fitted a new starter motor to my 125 s/wing yes a Honda with a French starter motor, but i think it to is a replacement motor.
Lyn.
Lyn.
