gn2 wrote:SpikeOne wrote:The memsahib failed because she applied both brakes at the same time!
Instant fail...
What total aund utter crap.
How the F can using the brakes correctly get you a fail?
Because you are expected to put a pause between the front going on and the back.
Say your full name between the brakes, (apparently), and that'll be about right.
If you press the back before the front or don't leave enough of a time gap, that'll be the end of your test. In her case, she realised that she was about to do it wrong so she visually removed her foot sideways from the pedal, and they failed her because they said she no longer had control.
Apparently it's because pulling in the the front brake hard has a tendency to take the grip off the back wheel due to the weight being shifted forward during braking. When this happens, there is more chance of a rear wheel skid if the brake is already on, so you're supposed to leave it until some of the speed's been removed, which increases the grip on the back wheel again.
No, I'm not sure I believe it either, but there you are.
Personally, I try and balance it out, but with the braking on the front of the Downtown being noticeably less than the back, if I had to jam them on hard without thinking, I'm not sure that I wouldn't skid anyway. And I have no idea how you are supposed to pass if you have linked brakes!
