Polini Maxi Hi-Speed variator
Brimma
Current Ride: Forza NSS300
Re: Polini Maxi Hi-Speed variator
Post by Brimma »
Brisk AOR12LGS now ordered
Anyone had any experience of these....
http://www.ebay.co.uk/itm/120844762906? ... 1438.l2649" onclick="window.open(this.href);return false;
#cantstopmodding
Brimma wrote:Brisk AOR12LGS now ordered
#cantstopmodding
I like foam filters, but prefer the more sophisticated and cheaper RamAir option, buy a sheet and trim it yourself, I did two scoots from one piece.
This has two densities so have to fit it the right way around.
RamAir
Brimma
Post by Brimma »
poldark wrote: I like foam filters, but prefer the more sophisticated and cheaper RamAir option, buy a sheet and trim it yourself, I did two scoots from one piece.
RamAir
Thanks, I take it cutting is quite easy using the original as a template (I'm not very technical, as you can see)
Brimma
Post by Brimma »
Oh dear.......I've just found this
http://motosmart.eu/polisc.pdf" onclick="window.open(this.href);return false;
RamAir
Well I managed it so it can't be that hard!
It'd clearly be easier if they made specific ones but it cuts easily with scissors. It's a dry item, so no messing about with oiling.
As you say use the old one as a template, I just made sure I allowed too much and then trimmed carefully to ensure there's sideways pressure on the airbox to hold it in place, though I think most Piaggio units have plastic "pins" on the outer half to hold things neatly.
I did an X9 250 and SH125 from a single piece, for a fiver. Apart from being cheaper this stuff is more efficient so allows greater airflow and is washable and reusable, that's gotta be better than paying out regularly for paper filters.
Brimma
Post by Brimma »
poldark wrote: Well I managed it so it can't be that hard!
Now for the really dumb question
Which way round does it go? :-(
The denser material (darker colour) goes "engine-side", so the larger portion, which is less dense gets the airflow first.
Sort of logical but I did call them to check anyway.
Brimma
Post by Brimma »
poldark wrote:The denser material (darker colour) goes "engine-side", so the larger portion, which is less dense gets the airflow first.
If there's two ways of doing something you can guarantee I'd do it wrong
MjW
Current Ride: TMax 2009 ABS
Post by MjW »
#cantstopmodding
Nice! Let us know of the results when you've had some time to play with it.
Brimma wrote:Oh dear.......I've just found this
Hmm. I'd go for this. Universal fit. lol
On the move with Tapatalk
Brimma
Post by Brimma »
I doubt I'll be able to pin it down as to exactly what has done what to be honest
I'm hoping it's going to go from standard to having Dr Pulleys, Brisk spark plug and Ram Air filter in one fell swoop
She's quick enough standard, so with those fitted it should be fantastic, and hopefully a lot smoother :-)
