Quite a few differences. The original Vision was as agile as a gazelle, this one is even better. Slightly bigger wheels I think and it feels even lighter (although its only 2kg lighter). It feels like its on rails when you go around corners. Its just a pity that when you come out of them not much happens.
First service on new Honda Scooter, where?
- Bingo
- Current Ride: BV 350 Honda Vision 110
Re: First service on new Honda Scooter, where?
- Greyerbeard
No separate starter motor, no - the alternator is also the starter! You can trust the stop/start; it works fine on the Forza 125 and you soon get used to it. As you say, the engine just springs into life with no delay.
1964 Matchless G3
1989 Honda C90
1998 Honda CB250 Nighthawk
2025 Honda ADV 350
1989 Honda C90
2025 Honda ADV 350
- Bingo
Does it not cause wear and tear though on the alternator and battery? I probably will use it in towns but out here in the sticks it seems pointless really.Greyerbeard wrote: Mon Mar 28, 2022 5:35 pm No separate starter motor, no - the alternator is also the starter! You can trust the stop/start; it works fine on the Forza 125 and you soon get used to it. As you say, the engine just springs into life with no delay.
newscooter
I think that these things used to be called dynastart in the good old days. I suspect that my Trojan bubble car had something of that nature.
- Waldorf
The Messerschmitt Cabin-Scooter certainly did and in order to get the thing to go backwards, the driver had to stop the engine and start it again in reverse - the dynastart went both ways - meaning one could go almost as fast backwards as forwards.
- StephenC
- Current Ride: Kymco DT X360
And bloody lethal either way!Waldorf wrote: Tue Mar 29, 2022 2:56 pm The Messerschmitt Cabin-Scooter certainly did and in order to get the thing to go backwards, the driver had to stop the engine and start it again in reverse - the dynastart went both ways - meaning one could go almost as fast backwards as forwards.
Can is not the same as Should
Mister Paul
I've just tried to book my ADV350 in for its first service. Fowlers can't do it until mid-May. Thunder Road want £250.
Mid May? That is a helluva long time away! By which time, you are likely to have done well over the 600 miles!
Mister Paul
I've managed to book Thunder Road for mid-April, which I can just about manage. Will probably get a service plan.MrGrumpy wrote: Tue Mar 29, 2022 6:05 pm Mid May? That is a helluva long time away! By which time, you are likely to have done well over the 600 miles!
chinnorbiker
- Current Ride: Honda Forza350
My “main dealer wanted over £160 for first service so I asked my trustworthy mechanic to do it for me.
However, he can’t order the oil filter from his usual supplier without the correct part number: does anyone have that information, please?
