As well as the Belt & Rollers they suggest i order Sliders i guess it covers all wear issues.MrGrumpy wrote: Fri Oct 27, 2023 7:58 pmSeems very premature....I've just replaced the V-belt on mine after 12k miles, and everything was fine and the belt looked brand new. Also replaced the rollers which looked fine after 12k (or maybe18k) miles. I put MrPulley sliding roller thingies on instead as they are supposed to last longer. You may have an issue, but it really shouldn't be a wear problem after 10k miles, unless you REALLY thrash it.Betty wrote: Fri Oct 27, 2023 6:56 pm Bit worried now the V belt has just started slipping on my Mk6 when given full beans and i'm on 10k Yamaha want £700 for the 12k service which includes the Belt change.
The Mechanic said it sounded like the Rollers needed replacing.
Thinking back...there was a problem with early mk6 CVTs - I had some funny issues when running, and it seemed to get stuck at 6000rpm. Yamaha could be persuaded, albeit with difficulty, to replace the whole unit under warranty.
Tmax drive belt snapped
- Betty
- Current Ride: Tmax 530 DX
Re: Tmax drive belt snapped
Betty the Scoot
Hello Betty, belts don't normally slip unless they are near to or about to break. Even very worn belts don't normally slip. The impression the belt is slipping is often caused by the rollers sticking due to dirt & other debris in the variator.
The DrPulley sliding thingies replace the rollers, but they also sell some 'sliding pieces' the function of which I can't fathom.Betty wrote: Sat Oct 28, 2023 10:42 pm
Thinking back to my CVT problem, it did give the sensation of slipping...ie revs would rise but no extra drive would occur, but this would only be a high revs and speeds.
Or the clutch pads need replacing.Data wrote: Sun Oct 29, 2023 9:40 am Hello Betty, belts don't normally slip unless they are near to or about to break. Even very worn belts don't normally slip. The impression the belt is slipping is often caused by the rollers sticking due to dirt & other debris in the variator.
- Betty
We shall seeFunkycowie wrote: Sun Oct 29, 2023 12:53 pmOr the clutch pads need replacing.Data wrote: Sun Oct 29, 2023 9:40 am Hello Betty, belts don't normally slip unless they are near to or about to break. Even very worn belts don't normally slip. The impression the belt is slipping is often caused by the rollers sticking due to dirt & other debris in the variator.
Betty the Scoot
Pukmeister
If its your clutch plates, that is very premature wear.
I rag my Tmax everywhere once warmed up and yet my plates were fine until the slip started at 46,000 miles.
Sod paying the OE Yamaha clutch plate prices (which are eye-watering), I got a Malossi full clutch plate kit for about £95 and modified my variator holding tool to fit the clutch pack so I could undo/re-tighten the basket retaining nut. I also fitted uprated springs to my clutch basket for taller RPM lock-up. The compensator spring on the secondary sheave is a yellow Malossi racing spring that gives an extra 500rpm of 'kickdown' under heavy acceleration.
With the 16 gramme Dr Pulley slider set in the variator, yellow compensator spring and Malossi clutch kit all combined it rides really good.
- Betty
New V Belt, Rollers and Sliders fitted and Betty is running as smooth as silk , feels like a new scoot.
V Belt looks brand new but the Rollers have small flat spots just pleased it wasn't the Clutch
Betty the Scoot
