- anonstarter
- Current Ride: Pending
Ditto!
- Zed
- Current Ride: Trek 7300
Put a new battery in.
Was struggling to start, even after 12 hours on an optimate, so new battery time.
Changed headlight bulb. Filled up.
- ridinhigh
- Current Ride: GTS 300
took cover off and gave her a quick dust over, gleaming again lol
i Forgot to get a pic of the mount, i will do it when it stops hissing down..
- ridinhigh
lol we have had no rain today lol
- Deeping
posted off insurance claim form due to some tin top hitting me
Never instal version 1.0
Well i have been to the shed and i did get wet just for you chaps
I chopped the ball from a Ram mount
drilled and threaded it, removed the shinny black top cover
it just pulls up and off. checked out the lay of the land and chopped a lump of steel to fit, drilled &
bent to correct angle. I then removed the middle cover and bolted said lump of steel in place. Then
the tricky bit, i had to do some stuff with the ruler to get it marked out for cutting ( top cover )
took the dremel to it and it fits
popped the cover back on and fitted the ram ball.
Next whist i was in the shed i held the Givi screen in place in order that you could see the
difference in the Honda and Givi screens coverage of the hands..
PS: the Ram arm is the small one, i just need to find a spot to drill some more plastic to fit the power outlet..
Oh! and fit the charger socket too.
Lyn.
PPS: the Givi screen are as tall as a sky scraper so will need 4 or 5 inches cutting from the top ..
Lyn.
barryG
Very nice Meldrew, I rode up there last summer on the Xevo. Its a bit of a treck to the Denkmel too isnt it, was without scaffolding then.... funnily enough there was a guy there on a Silverwing too!
