Feeling Grumpy...
Zed
Current Ride: Trek 7300
Re: Feeling Grumpy...
Post by Zed »
FFS tosser.gif second (or third?) puncture this year. What is with all the sharp metal spiky shit spread across London streets?!
Definitely going to have to try a plug thingy, and then put some goop stuff in my tyres, it's right grumping me off!
EDIT: ordered some PunctureSeal off Amazon. Do i need to plug the superslow leak i currently have? or just gloop it up?
Wolf
Post by Wolf »
If it's a slow leak just put the correct amount of ultraseal in ( check amount for your tyre size ) it's never let me down
to make the ultraseal go in easier put the bottle in warm water first
I thought I had a puncture last week but I hadn't!
When I got back home from work one day, I saw something on the front tyre of the baby Burger, and found it was metallic, so I assumed it was a nail or something gone into the tyre....however, it wasn't going down. Took it to bike workshop next day and it turned out it was only a square of metal that had got pushed into the tyre, not a bolt or screw or something that had gone right through!
Looked a bit of an idiot going into the workshop for a bit of metal lodged in the tyre, but I'd rather it was that way round than me remove it at home and hearing that 'SSSSSSSH' noise.
Just to make sure, workshop put some sort of gunge in the tyre - blue this time! However, the tyre hasn't got a huge amount of life left in it anyway.
Wolf
Post by Wolf »
Blue is ultraseal (puncturesafe)
Sent from my GT-S5360 using Tapatalk 2
wuffstuff
Current Ride: Burgman 650
Post by wuffstuff »
Never argue with an idiot. They drag you down to their level, then they beat you with their experience.
Wolf wrote:Blue is ultraseal (puncturesafe)
I thought Ultraseal was the same colour as PunctureSeal (ie Pink). The colour is, of course, the most important thing about it!
Wolf
Post by Wolf »
Last bottle I bought this yr was blue for men
SpikeOne
Current Ride: SYM Jet 14
Post by SpikeOne »
How do you use that stuff?
Let the tyre down, inject it in, and then pump the tyre back up again?
I've heard good things about it, but never used it...
Spike
SYM Jet 14
Keeway Superlight
Yamaha address 110
Kymco Downtown 300i
Yamaha Vity
MZ ETZ251
Honda CD175
Honda CB250 G5
BSA Bantam D14/4
BSA Sunbeam
Honda C50
Wolf
Post by Wolf »
yes let the tyre down, take the inner valve out, connect the pipe to the valve stem (can be a bugger to get on but warm it up in hot water) connect the bottle to the pipe hold it up and squeeze the correct amount in ( check your tyre size with the guide in the box ) then re fit the inner valve and re inflate tyre then go for a short ride 2-3 miles you may notice a bit of vibe but don't worry that will go once it has spread inside the tyre
Zed
Post by Zed »
So do you do it at the garage? (for the air pump)
I might have a foot pump in the loft, but it'd be a bugger if it didn't work after deflating my tyre... Suppose i can do it at work, where the closest garage is much closer.
