I'm sure you want to install soonest, but maybe just try the Brisk plug first as this will likely change the engine characteristics quite significantly alone.Brimma wrote:I doubt I'll be able to pin it down as to exactly what has done what to be honest
I'm hoping it's going to go from standard to having Dr Pulleys, Brisk spark plug and Ram Air filter in one fell swoop
She's quick enough standard, so with those fitted it should be fantastic, and hopefully a lot smoother
Then perhaps do the sliders after, maybe together with filter, which I suspect will have least obvious impact.
Otherwise you'll not know what drove most benefit, as you will see a dramatic change...... promise!
