Thanks, this does make more sense then. The exhaust does make a lot more little pops and mini backfires than the original.Data wrote: Thu Jul 06, 2023 9:35 am Generally when fitting an aftermarket exhaust such as the one you have, the motor will run either richer by some way or slightly lean. Yours looks a bit rich with its mixture.
To Lambda or not to Lambda, that is the question.
- OneFootInTheGravy
