- frankiej1949
Took the cover off, rode it to work, parked up disclock on alarm on! Working til 5.00pm then it will be back home, park up, chain on rear wheel to anchor point, xena cable and alarmed disc lock on front wheel to anchor point, cover her up and say good night see you in the morning. Will give her a good clean on sunday.
- mottza
Rode it 52 miles back home.
Did an oil, oil filter and spark plug change. Waiting to stop snowing before I wash and put away.
Oil and filter, cleaned both air filters and...well.......I have to test ride it don't I dear?
No real snow here, sunny but bloody freezing
Found an old clamp in garage drawer and turned it in to a go pro pikeycam mount
Sweet!
Let us know how steady the picture is.
With my Atom I had written the mirrors off as too vibey but I'll give it a go if yours works.
When you load to you tube it will ask if you want shake sorted .Im not a head cam fan although thats most stable as its difficult getting aim right your heads moving all the time and if your helmet is in shot camera will focus on that and makes back ground blurry .Ill give it a go its cost nothing to make also can leave bracket on and just add camera when needed
Final postion for rearcam action extended cam to get box out of shot (run out of black tape)3 dogcam suckers on/off switch for archos cam clips on seat shall be on test at Midland scoots egg run on sunday.Shall put cargo net over box stop anything falling off it worked for Ena Sharples
- poldark
Looks like a James Bond rear firing rocket launcher, hope it works well.
