- tallpaul
- Current Ride: xmax 125
I'll show you mine if you show me yours...
Sent from my HTC One X using Tapatalk 2
- bornagainbiker
I bought a 12v Impact Wrench but not used it yet, so I hope that works without needing a tool....... or I'll be calling you Paul to borrow ur new tool...!
I use a impact on my nexusbornagainbiker wrote:I bought a 12v Impact Wrench but not used it yet, so I hope that works without needing a tool....... or I'll be calling you Paul to borrow ur new tool...!
- tallpaul
Yes Colin if you're stuck, I made it at work with some 3mm steel, I measured out for the pins & cut a hole with a hole saw, I got a mate to trim off the outside edge with the guillotine. The handle was Just lying around so I made use of itbornagainbiker wrote:I bought a 12v Impact Wrench but not used it yet, so I hope that works without needing a tool....... or I'll be calling you Paul to borrow ur new tool...!
Deleted User 796
"Re: What have you done to your Scooter today?"
Scratched it. Again. FUCK.
- martb4632
- Current Ride: LML Star 150 4 Stroke
Painted hammerite under the front mudguard seam on the LML as this is a common place for corrosion to start on these scoots and their Vespa px cousins. They are also a pain to replace compared to a lot of other scooters and bikes.
Also disconnected the indicator buzzer as although I realise it's a safety feature I find it really embarrassing negotiating all the traffic lights and roundabouts in town with the scoot going Beep Beep Beep Beep
- MjW
- Current Ride: TMax 2009 ABS
Tried changing the Akra pipe myself. I failed, I'll call and book a time at the mechanic tomorrow. lol
On the move with Tapatalk
- bornagainbiker
Stripped my Burgman 400 CVT. The cover with bearing came off fairly easy. The oem double toothed belt looked ok but most of the variator rollers were like a 50p piece with plenty of hardened dust in it, but not as much as I was expecting. My £19 delivered 12v Impact wrench easily took the variator nut off, a real recommendation with no holding tool needed, just a hand hold of the finned plate. Ordered 8x 26x13 17.5g rollers from LLexeter on fleabay and were dispatched same day. Also when open changed to Final Drive oil, only 5 minute job. The 5 shoe clutch has loads of life left. Cleaned everything in preparation to fit the rollers and re assemble.
- mottza
Checked the oil, painted the stand and went down to halfords and b and q on it.
- poldark
What Impact wrench did you invest in?bornagainbiker wrote:Stripped my Burgman 400 CVT. The cover with bearing came off fairly easy. The oem double toothed belt looked ok but most of the variator rollers were like a 50p piece with plenty of hardened dust in it, but not as much as I was expecting. My £19 delivered 12v Impact wrench easily took the variator nut off, a real recommendation with no holding tool needed, just a hand hold of the finned plate. Ordered 8x 26x13 17.5g rollers from LLexeter on fleabay and were dispatched same day. Also when open changed to Final Drive oil, only 5 minute job. The 5 shoe clutch has loads of life left. Cleaned everything in preparation to fit the rollers and re assemble.
