Highest Mileage Forza 300
Re: Highest Mileage Forza 300
Néed a bigger screen like the giving air flow that I have on mine.
Generalpurpose
Post by Generalpurpose »
Hi all. clocked over the 12k Mark on my black Forza 300. so together with my first grey Forza 300 I am now over 20k miles on a Forza and I still love it.
both scooters have been reliable (the first one got written off in a non fault accident). only issue I had with both was leaky water pump seal.
mpg over the miles is around 85 ish and I can get 200 miles from a tank!ImageImageImage
Sent from my SM-G950F using Tapatalk
14.3k miles on mine.
Generalpurpose
I have a bigger screen for the black scoot but have not yet fitted it...maybe after the summer
I must admit its rare when I get over 200 miles to a tank. Has been known to do 100mpg at times though.
Generalpurpose
getting to the time of year again when my scooter is just plain filthy...ImageImage
Was an Swing 125 with 60 k miles still running said could do with a re build so I'd guess you can get same if looked after .
Generalpurpose
give the scooter a wash and and engine oil & filter change.
strangely straight after the wash with the old oil still ad I was warming it up a bit I had the oil pressure lamp glowing a bit...but not full on. so my guess it's just water from the wash that caused it.
it was still there after the oil change too but the bright light goes straight out telling me oil pressure is building ok...and it just just a moisture falls earth etc.
my boy helped with cleaning the beast..
I will let it dry up and see if the glowing light disappears again...fingers crossedImageImageImage
muddyfox
Post by muddyfox »
That's scrubbed up well compared to the earlier photos.
Muddyfox (Nottingham)
Ride safe
Generalpurpose
yes and that glowing oil light is back to normal too...just tried it.
my guess of just some moisture was probably correct.
