StevenM wrote:
michaelphillips wrote:i have had a pirelle diablo on the front for nearly 2 years, caim on when i got scoot, i have found it to be very grippy, warms up well and have never had any problems with it, i run the front at 30 psi cold which warms up to 34 psi in use, you can always tell if it goes down to 28 psi cold , not sure whether to get another or go with bridgestone, as i like the rear battleaxe i got fitted, the H rate tyre is more expensive than say the s rated tyres
mine say 42 psi on the front and back, i have always inflated to this!!!!!
both the workshop manual and owners manual states
Tyre pressure (cold) front 2.1 bar
Tyre pressure (cold) rear 2.3 bar (2.5 bar with passenger)
which is 30 psi front and i am 2 up for 50% of time so i go with the later for rear which is 36 psi COLD Tyres
bridgestone and other tyre manufacturers have there own thoughts and are usually 2 psi higher.. yet the owners manual is specific to the model, weight of machine etc..
if you are doing 42 psi when cold tyres they will rise by another 4 psi when running through friction,
you will have a bumpy ride :) and loss of stability at high speed as with friction with road, and you will wear your tyres out faster over
their centres, not advised and also loss of forward traction :) :) :)
BenR
Post by BenR »
I've got the bridgestones I run 32psi front & 30psi rear. Steve if you run your tyres that high they will go bald quicker not to mention that the ride will be so stiff you'll go through headstock bearing quicker, also if you ever get a puncture on the move it will make rather a nasty mess. I suggest reading what it says on the tyre again as that sounds to me like that's maximum inflation rating not what you should be running them at.
Are you sure you're not reading the "max psi" label on the sidewall? :kiss:
Post by StevenM »
poldark wrote:Are you sure you're not reading the "max psi" label on the sidewall? :kiss:
Probally will check this tomorrow. :D
well did a job today been putting off for the better weather, i have always wanted to do, set the tappets i asked the piaggio dealer they wanted £200 to do it as takes 2 hrs!!! well it took me 5 hrs of stripping the scoot as i did not want to drop the engine, finally got there in the end.. Valve clearance: intake: 0.15 mm (when cold) Valve clearance: exhaust 0.15 mm (when cold) the 2 inlet valves were open too much as were the exhaust valve clearance, i dont think they were, or have ever been done as its not seen a dealer in 25,000 miles so was prob too young in miles to be checked for its first 16,000 miles
the scoot was not noticeably tappet loud when you listen, just a job thats been on my mind as a to do... so done it now and its very quiet at the front , all i can hear is the tranny up close Ha Ha just done 10 miles and feels about the same really, but was two up and took it steady, will have a good run monday :) :) :)
Taipan
Post by Taipan »
Took the cover off the Nexus and was about to start work on it and then it pissed down. So I put the cover back on it. :roll:
Torrential rain in Essex.
jamie
Post by jamie »
sun in torbay.... so washed the x8 for the first time this year :oops:
PD110961
Current Ride: Burgman 400
Post by PD110961 »
nothing till i buy it tonight!
MT606
Current Ride: burgman 400 c90
Post by MT606 »
put another new windscreen on......
