you be careful
12/07/14 - Essex / Hertfordshire Ride
Re: 12/07/14 - Essex / Hertfordshire Ride
if you go m3 then m25 dont forget m25 will split at junction 5 so stay left there... from the m3 when you get to m25 about half way on m25 there is a fuel station.. then depends if you wanna stay on m25 over dartford brigde or come off it onto the a20 and go to a12 blackwall tunnell then a left onto m11
you be careful
you be careful
what you got to do to the girlnexusmaximus wrote:Bugger! ... was hoping to have the Nexus back on the road for this, but won't have the time to fix her beforehand... looks like i'll be rocking up on the SH300. Looking forward to it, not been on a rideout in quite some time.
- spaceprobe
Anon that's a long ride so you be careful, especially has you are only a little one. Perhaps a Air Hawk cushion for your rump may be a good idea
- Ferrit
- Current Ride: MP3 400ie
I would always go anticlockwise on M25 from the M3 to M11, no tolls and apart from M4 section the traffic is much better.michaelphillips wrote:if you go m3 then m25 dont forget m25 will split at junction 5 so stay left there... from the m3 when you get to m25 about half way on m25 there is a fuel station.. then depends if you wanna stay on m25 over dartford brigde or come off it onto the a20 and go to a12 blackwall tunnell then a left onto m11
you be careful
Ferrit wrote:I would always go anticlockwise on M25 from the M3 to M11, no tolls and apart from M4 section the traffic is much better.michaelphillips wrote:if you go m3 then m25 dont forget m25 will split at junction 5 so stay left there... from the m3 when you get to m25 about half way on m25 there is a fuel station.. then depends if you wanna stay on m25 over dartford brigde or come off it onto the a20 and go to a12 blackwall tunnell then a left onto m11
you be careful
thats a good idea, sorry as living the other side i naturally go towards gatwick, but makes sence to head to heathrow and tootle up there as you will end up at the top side where annonstarter needs to be
nexusmaximus
- Current Ride: nexus 500-fuoco-burger 650
Gotta replace the sprag clutch, and give her a full service, belt, rollers etc.michaelphillips wrote:what you got to do to the girlnexusmaximus wrote:Bugger! ... was hoping to have the Nexus back on the road for this, but won't have the time to fix her beforehand... looks like i'll be rocking up on the SH300. Looking forward to it, not been on a rideout in quite some time.
thats a big job, have a ganders at the water pump metal spindle when off to make sure not wearing a groove, and then you just need the water pump seals, i got mine for £12.40 delivered for the nexus mk1 mk 1 water pump just trying to save dosh
Whatsisname
I would go that way too, but isn't that clockwise?Ferrit wrote:I would always go anticlockwise on M25 from the M3 to M11, no tolls and apart from M4 section the traffic is much better.michaelphillips wrote:if you go m3 then m25 dont forget m25 will split at junction 5 so stay left there... from the m3 when you get to m25 about half way on m25 there is a fuel station.. then depends if you wanna stay on m25 over dartford brigde or come off it onto the a20 and go to a12 blackwall tunnell then a left onto m11
you be careful
- anonstarter
- Current Ride: Pending
Thanks gents for your advice.
I'll take the M3 M25 & M11 as advised.
I think that was an 'initiative' test.Whatsisname wrote:I would go that way too, but isn't that clockwise?Ferrit wrote:I would always go anticlockwise on M25 from the M3 to M11, no tolls and apart from M4 section the traffic is much better.
- StephenC
- Current Ride: Kymco DT X360
On a scooter I would always opt for the shortest route, rather than the "fastest" route that my satnav tells me is somehow better. But if you've been riding hours you may just want to get it over with, so I understand that.
But once I get to the M25 I'd continue on and head straight into central London, doing a bit of sightseeing along the way. Then along the Embankment to Tower Bridge, then A11, A12 (at Bow) then M11. If you don't want to do the M11, then come off the A12 at Leytonstone and follow the signs for Epping. Once past Woodford it's a nice ride though the forest and you pass the biker's tea hut at High Beech for a cuppa and a chin wag.
Can is not the same as Should
