mikbak
Current Ride: 2001 Silverwing FJS600
Post by mikbak »
pikey wrote:Rode it to get petrol blow tyres up had it before Christmas first time been on it .
Dynamite or TNT?
ridinhigh
Current Ride: GTS 300
Post by ridinhigh »
got it all in bits to to ACF it all ,tho im not really impressed with it its very runny
think it ought to been Dinitrol, its a bigger job than you think to take floor pan off on a gts
ridinhigh wrote:got it all in bits to to ACF it all ,tho im not really impressed with it its very runny
You have to heat up the can to make sure it comes out as a fine mist, otherwise you'll just waste it, sit it in a bucket of hot water for 15-20 mins first.
fitted pre wired 12v led`s to replace the ancillary bulbs so they will never need changing, all went well happy chap, been meaning to do this for ages :D
MjW
Current Ride: TMax 2009 ABS
Post by MjW »
michaelphillips wrote:fitted pre wired 12v led`s to replace the ancillary bulbs so they will never need changing, all went well happy chap, been meaning to do this for ages :D
Nice! Post a pic!
On the move with Tapatalk
Nice! Post a pic!
its basically the small bulbs were changed over, all the warning light bulbs as they dont last that long, with pre wired 12v led bulbs, so cut out the wiring and heat shrink the new bulb wires in to the wiring, its all put back together now, i got the 12v pre wired bled`s from china, i bought 24 for about £2 delivered, saves having to use the led holders etc , nice and easy, you can get them from here http://www.ebay.co.uk/itm/10X-5mm-White ... 19e98b4bf7" onclick="window.open(this.href);return false;
This started off looking for a leak in clear water ,then progressed to soaping outside of tyre still looking for leaks then I thought may as well wash wheel while I'm at it .This is what is so good about Vespa's :lol: :lol: :lol:
ridinhigh
Post by ridinhigh »
the stuff i got came in a bottle with a a separate spray bottle so you had pour it into the spray
bottle and it dint have a spray only a stream
Post by StevenM »
Had the belt changed on Thursday.
Today adjusted the chain as it was slack. Should have been 28-30mm and it was 60mm oooops. Then washed it.
Picked it up from the garage and took it to the coast.
