Thanks to the generosity of Spannerman (Dave) I fitted the missing front indicator mesh to the X9, also following his suggestion I levelled the front forks, which has really helped with the jarring I was getting.
went out for a quick blast, and replaced the air filters and crank case filters, just shy of 6k miles and they were filthy...
the Hiflo ones I got from MSA - great deal - the left hand air filter is a little tight / not an exact fit - may just be an odd one - cover etc screwed on fine.. the others fitted fine - same air boxes etc as the 400 Majesty.
Ferret
Current Ride: Aprilia srv 850
Post by Ferret »
Took the srv in for warranty work today comprising of a new rad and headlight unit .Once the rad was off to inspect i decided to get a fender extender and modify it to fit just to give the rad a better longer life .
Good thinking.
One of the things Iike about the Forza design is that the front mudguard extends right down to the level of the bottom of the fairing.
anonstarter
Current Ride: Pending
Post by anonstarter »
Agreed. I've lost count of the amount of times I've come across 'stone through radiator/oil cooler/fairing/exhaust, etc...' or '...full of crud...'. Shortsighted 'designers' is putting it politely! My 2008 Citycom forces the water back out in front of the wheel - I call it the Moses effect... :D
Ferret
Post by Ferret »
My cbf1000 honda did the same and if sat at a junction too long on a wet day all you had was steam everywhere from all theshit on the rad ,my m8 has a newer one which did just the same so a fender extender cured it .
kishan
Post by kishan »
fitted led white side light bulbss and carbon fibre pattern tax disc holder.
Took wheel off took off my Hexagon down tyre place to get rim leak sorted they failed said was too far gone.Came back took tyre off myself cleaned up bead got flaky paint off refitted tyre seems OK.May have well done it myself in first place and saved a fiver .
Nothing today, tomorrow will be a day of stripping panels, replacing filters, oils, sparkplugs, brake pads and likely a few swear words.
Sold it
