Post by StevenM »
Fitted my fender extender, as it fell off ages ago. Hope the tiger seal holds it. Lubed the chain. Filled up.
Did 190 miles to the Ace and back.
MjW
Current Ride: TMax 2009 ABS
Post by MjW »
Changed to the shorter sport screen. Yet again.
On the move with Tapatalk
Raven
Current Ride: Vespa SS180 - Kawasaki 1400GTR
Post by Raven »
Put two new Mirrors on the GTS 250ie :D
Raven
SkuTorr
Current Ride: Tmax Mk3
Post by SkuTorr »
MjW wrote:Changed to the shorter sport screen. Yet again.
I just slide mine DOWN!
2009 Majesty 400 (sold)
Taipan
Post by Taipan »
Fitted new bearing to the swinging arm plate thing. Wife was a bit miffed when I baked it in the oven for 10 minutes at 200 degrees! :lol: Then I took the Dr Pulleys out and put OEM rollers back in and then fitted new front pads and gave it its bi-annual wash! :D
mac65
Current Ride: Honda ADV 350
Post by mac65 »
Fitted the panels that ive been waiting for months. Also did an oil change and a quick was to finish. Ready now for the trade in!!
Sent from my ME173X using Tapatalk
enjoy eXtra to the Max
ollie
Current Ride: Honda Forza 300
Post by ollie »
Fitted mudflap to the Silverwing using Meldrew's idea of a cut down flower pot and I am pleased with the result.
Thanks Meldrew.
Next job is to fit the Acerbis hand guards which rely only on compression inserts in to the end of the handle bars for fitting. On attempting to mount on the Honda I find that the bars are not hollow and the guards foul the screen on full lock. Which is disappointing as I found they worked well with the heated grips, drastic modification maybe required. :shock:
Raven
Post by Raven »
Fitted a new/used exhaust on the GTS 250ie :D
Raven
ollie wrote:Fitted mudflap to the Silverwing using Meldrew's idea of a cut down flower pot and I am pleased with the result.
Thanks Meldrew.
If you remove the grips you will find a couple of holes 20mm or so from the ends, press the ;little tabs in with a diddy screw driver and pull out the inserts.. ;)
PS: i don't no what they are like on the Wing but they could be 6 or 7 inchs long :lol:
