jasg
- Current Ride: piaggio x9
Discovered that some little scroat has cracked the covering on my x9 digidash so not a good start to the day, but then my first grandson was born this afternoon so can,t really complain.
loving my maxi
piaggio x9 125
honda ps 125
piaggio x9 125
honda ps 125
TMax is idling 100revs higher on the Brisk plugs will need to adjust...
Filled up with fuel... so looking at my history mainly different plugs I get the following.
Brisk Racing LGS plugs fuel up 99RON (Riding it like I stole it)
MPG: 58.7
Miles: 128.4
Litres: 9.940
Denso Iridium plugs fuel up 99RON (Riding it like I stole it)
MPG: 51.7
Miles: 154.0
Litres: 13.54
NGK Plugs fuel up 95RON (Sedate commute)
MPG: 57.2
Miles: 158.6
Litres: 12.60
MPG: 58.7
Miles: 128.4
Litres: 9.940
MPG: 51.7
Miles: 154.0
Litres: 13.54
MPG: 57.2
Miles: 158.6
Litres: 12.60
Ferret
The brisk plugs allow you to ride it hard all the time and still get good mpg .
so are you saying you are enjoying the brisk plugs
did you tweak back the idle revs
good results though
Raven
- Current Ride: Vespa SS180 - Kawasaki 1400GTR
I haven't done the rev's yet.michaelphillips wrote:so are you saying you are enjoying the brisk plugsdid you tweak back the idle revs
good results though
Yes I am enjoying them because they are saving me money, the power is equal to the Iridiums, the engine doesn't run as hot, the only thing I really miss is the exhaust note has changed like its cleared its throat
Raven you supposed to clean the scoot with all the bits on it
Raven
Nothing like a good spring cleanmichaelphillips wrote:Raven you supposed to clean the scoot with all the bits on it![]()
Raven
Been out for a bimble... I am liking the Brisks more and more. Power delivery has improved greatly, so much so that short overtakes are noticeably easier. 0-60 takes a shade under 6 seconds.Funkycowie wrote:I haven't done the rev's yet.michaelphillips wrote:so are you saying you are enjoying the brisk plugsdid you tweak back the idle revs
good results though
Just looking on-line at the TMax stock 0-60 times... the MK3 time is 8.8 and the MKIV time is 6.5... so just with 16g Dr Pulleys and the Brisks I have taken off quite a bit
