HI Chaps, i'm after some data, anyone know where you download a manual for the k2 400 carbed model please?.
I want to know the alternator output in watts or amps please?
I'm just fitting some nice toasty heated grips, and wanted to know the margin for error we have here, am i going to get warm hands and a flat battery?
Ive done the grips, they were a piece of cake to do, the controller is going on the right side of the dashboard surface mounted.
I'm also fitting a battery monitor led arrangement, and i'm pulling clocks apart and fitting the single 5mm led inside speedo housing. very trick.
I'm amazed there is nothing to warn of a charging failure, till it all goes dark...
The second amazing thing i find is that there is no low oil pressure lamp???Anyone fitted one?
all the best, and thanks Paul
burger 400 k2 technical manual
baldy
- Current Ride: burger 400 k2 BMW 1150gs
Ive got a 400 burger and i'm lovin it.....
Milo.
Re: burger 400 k2 technical manual
i think the website is called whyworrymenot.com. hope this helps. or pop into your local friendly dealer who should loan you one.
baldy
Thanks for that, i'll have a look. ta.
There is Haynes workshop manual coming out for the Burgy 400, it should have been out in the summer but was postponed to this month (Dec)
baldy
i'll get busy and check.ta
