sorry to ask again but i know one of you guys will know
- amsmtb
- Current Ride: Suzuki burgman 400za l4
Hi all
was wondering if any one knew of a way of replacing the seal on the link from the header to the mmuffler. As for some reson not known by me my seal has just vanished leaving me with a nasty not to say ilegal exhaust blow. I seam to remember reading a ready for this but i can not remember ware. Any help is recived with my thanks.
Suzuki burgman 400 k5
Gilara nexus 500 2004
Suzuki Burgman AN400 k7 2006
Piaggio x7 125 2010
Yamaha Majesty YP125R 2000
jinun db50qt6 (NInja) 2007
Honda nsr125k JC20 1991
Piaggio x7 125 2010
- amsmtb
Re: sorry to ask again but i know one of you guys will know
Sorry its on a k7 400. And the seal is at the point ware the two pipes meet and are clamped
Piaggio x7 125 2010
Piaggio x7 125 2010
amsmtb, try this link. It should be the info you need.
Let us know how you get on.
http://burgmanusa.com/gallery/TechArtGu ... haustleak/
- TmaX9
Good instruction but strikes me that if you are going to all that trouble, fit proper gaskets, don't fudge it with tin foil!
You only end up doing it more often. They aren't all that expensive and will last you years again.
That's for sure. I wouldn't use tin foil either. Hadn't noticed the second page instruction on doing that. Get the proper gaskets.
