Might be a head gasket but no option but to top up and limp it into work tomorrow... looks like the Smart car aka Thunderbird 4 will be called into action!
Oh bugger!
- Sgt Ernie Bilko
- Current Ride: 2010 Tmax mk 3
Oh bugger!
Vespa GTS250 flew home tonight at a steady 75mph... humming along nicely and showing no apparent problems. Parked her up to return ten minutes later to a huge pool of coolant dripping from the engine mounting area. No visible split pipes, but the coolant level is below minimum...
Master Sgt E Bilko
RA15042699
Co B 3rd Platoon
RA15042699
Co B 3rd Platoon
monty9120
Re: Oh bugger!
hope its nothing serious mate. see if your mechanic can have a look.
there normally bullet proof so hope its a loose pipe or something
GILERA NEXUS 250
- R1K SU
- Current Ride: Burgman 650
Re: Oh bugger!
I know im prob way off but didnt Gillera GP800's have a problem with water hoses comming off, just all owned by same company, same people may make them ??
Yam RD350 YPVS
Honda VFR750
Yam RD 350 air
Kawa GT550
Kawa ZZR600
Yam FZ1s
Burgman 650
Suzuki GSXS1000
Suzuki GSXR1000 K7
Zero FXS
Honda VFR750
Yam RD 350 air
Kawa GT550
Kawa ZZR600
Yam FZ1s
Burgman 650
Suzuki GSXS1000
Suzuki GSXR1000 K7
Zero FXS
- johnp
- Current Ride: The Wife
Re: Oh bugger!
If it didn't have problems it wouldn't be italian.
- masterchop
hatter
- Current Ride: Honda SH 300
Re: Oh bugger!
Did you put in on side stand after your blast? If so coolant could have meerly just expanded out of overflow when hot and scoot at angle.
Had this happen to me once and thought the worst, worth checking.
- Sgt Ernie Bilko
Re: Oh bugger!
Nope. Always on the centrestand. I hate those bloody springy suicide stands... I have taken the seat bucket out to check the pipes but all looks dry.... my teccy thinks gasket. Will let you all know tomorrow....hatter wrote:Did you put in on side stand after your blast? If so coolant could have meerly just expanded out of overflow when hot and scoot at angle.
Master Sgt E Bilko
RA15042699
Co B 3rd Platoon
RA15042699
Co B 3rd Platoon
barryG
Re: Oh bugger!
Usually water comes out of the pipes where they go into the waterpump, they have naff clips which youjust remove and replace with jubilee clips and a little sealant.
- Sgt Ernie Bilko
Re: Oh bugger!
Not that easy Barry.barryG wrote:Usually water comes out of the pipes where they go into the waterpump, they have naff clips which youjust remove and replace with jubilee clips and a little sealant.
Master Sgt E Bilko
RA15042699
Co B 3rd Platoon
RA15042699
Co B 3rd Platoon
barryG
Re: Oh bugger!
Blimey, thats weird eh? It shouldnt happen on such a new scoot unless its been run without coolant for ages. Id say a bit of poor quality control is to blame?
