how do change headlight bulb
ridinhigh
Current Ride: GTS 300
Post by ridinhigh »
hi lads,
how do i change the headlight bulb on a GTS300,with breaking owt? ,cheers
keith
R1K SU
Current Ride: Burgman 650
Re: how do change headlight bulb
Post by R1K SU »
Try YouTube ?
Yam RD350 YPVS
Honda VFR750
Yam RD 350 air
Kawa GT550
Kawa ZZR600
Yam FZ1s
Burgman 650
Suzuki GSXS1000
Suzuki GSXR1000 K7 😜😜
Zero FXS
Wolf
Post by Wolf »
Take old bulb out and put new in :lol:
Sent from my WT19i using Tampax 2 :-)
ridinhigh
Post by ridinhigh »
pmsl, but dont know to get headlight off thats problem
Liam
Post by Liam »
Wolf wrote:Take old bulb out and put new in :lol:
Stop using Tampax Craig
R1K SU wrote:Try YouTube ?
Youtube 's a godsend
Especially Micbergsma
ridinhigh
Post by ridinhigh »
thanks RIK for [you tube] advice found it
that guy's like a legend, anyone know his story? i have him on my favourites. Came across when looking through burgman 400 videos. He's done thousands miles of long runs on it.
The manufacturers should not make it like that, You should be able to change the bulb at night without removing much, ie. the way things were made it, was one holding screw and the rim pops out. It's penalty points for riding without lights.
You need quick access to change bulbs, one of the worst cases is a Ford Ka model, where the wheel and inner wheel arch needs removing. So you see many driving around with one headlight working.
From now on, a first test for me will be access to the headlight bulb, if they can't make that easy, then what else is a mare to do on the product I'm looking at.
I like the Vespa, my old Rally 200 was easy to work on, engine out and back in an evening if needed. headlamp bulb 5 minutes, times have changed not always for the better.
Wolf
Post by Wolf »
Liam no :lol:
Dave Weller wrote:The manufacturers should not make it like that, You should be able to change the bulb at night without removing much, ie. the way things were made it, was one holding screw and the rim pops out. It's penalty points for riding without lights.
Many many cars require a wheel off and inner wheel arch liner removed to replace a headlight bulb. That's not new. But darn annoying!
