Silverwing Variator.
Scootaboy
Current Ride: FJS 600 SilverWing
Post by Scootaboy »
Hi,
What are the advantages of changing the variator on my 600 Silverwing.Is this something worth changing? Does it lower the revs or raise them for more acceleration? What is the best one to go for and where is the best place to get one?
Sorry about all the questions but if you don't ask you don't know :D .
Thankyou...
Scootaboy.
There's no such thing as poor performance, only inappropriate expectations
Image Image
Re: Silverwing Variator.
Scootaboy wrote:Hi,
Thankyou...
Scootaboy.
Most aftermarket variators allow more revs to be used to allow better acceleration, both from rest and in mid range. Obviously it has no real effect at high speeds. The original burgmans were very stodgy off the line, and the Tmax is rather stodgy around 30mph, so these can benefit from a new variator.
An after market variator is supposed to be more efficient, but I suspect the gains aren't huge.
Whether its worth it is up to you! I don't know much about the 'wing. Do you feel that you need better acceleration, or are there any flat spots with the standard setup?
The biggest name is Malossi (there is a Malossi online store), and can be fitted by most skilled mechanics. There are also Malossi tuning places. There are other makers, notably Polini
Again I'm no Silverwing expert, but rather than a complete variator change I know several on here have "upgraded" just the rollers to the Dr Pulley sliders and seen positive (and far cheaper) results.
http://silverwing600tech.proboards.com/ ... =17&page=1
http://www.silverwing600.com/t3626p60-d ... stallation
mightbesane
Current Ride: Burgman 400 K4
Post by mightbesane »
I completely understand the desire to tinker but I'm not convinced of the cost/benefit of most mods. However, I'm a believer in Dr. Pulleys as the one worthwhile performance enhancing variator mod. In every scoot I've owned, they show significantly less wear over time than standard rollers and have improved acceleration off the line. From a cost/benefit standpoint, they can't be beat.
Sylar
Post by Sylar »
I've had my Silverwing for just over 2years now, and as Meldrew says, don't be tempted to mess about fitting all these so called "improvements". I would agree with mightbesane though as i have now done just over 21,000mls, and i intend to fit Dr Pulley sliders when i do the service at 24,000mls. I will also check on the new Belt i fitted at 16,000mls, and of course change the oil and air filters, oil, and final drive oil. If it needs new brake pads i will change them along with the Brake fluid. Just enjoy the bike, Mr Honda did a good job and it is fine as it is. :)
burgerman
Current Ride: Honda FJS600 Silverwing
Post by burgerman »
Meldrew wrote:I don't think the Silver Wing needs playing about with, I've never been convinced you need to fit any of this Dr Pulley, J. Costa, Power Commander stuff. That also goes for HyperPro fork springs, fancy exhausts and all the other stuff that Silver Wing owners think they need after reading too many forum posts.
+1. Seems to me Honda got it right with the Silver Wing (except for the OEM screen!), so no need to fiddle. If it ain't broke, don't fix it!
Normsthename
Post by Normsthename »
I had a J Costa Fitted to my Silverwing and it really pepped up the performance, but it didn't do anything for fuel economy!
I have the Jcosta Variator I removed somewhere.
PM me if interested ;)
1975 Honda GL1000 Goldwing
Scootaboy
Post by Scootaboy »
Thanks for the advice,it was just what I was after,you gave me the pro's and cons,which is what I wanted.I shall leave the variator stock.
Scootaboy...
Image Image
