Yesterday I thought it'll be good to change the gear oil on my Citycom. I bought 1ltr of Castrol Syntrans 75W 90 which is recommended by fellow Citycom owners...
In the manual it says: (
And it's here that the confusion began."Gear Oil: Oil level inspection. Park the motorcycle on a flat surface with main stand. Turn off engine and remove oil inspection bolt.
Gear lubrication oil quantity has to be measured with measure device. If oil level is too low, add gear oil. Install oil inspection bolt.
Gear Oil Change: Remove oil level inspection bolt. Remove drain plug and drain oil out. Install the drain plug after drained. Make sure that the drain plug washer can be re-used. Add oil to the specified quantity from the inspection hole.
Gear Oil Quantity: 160 c.c. when replacing.
Make sure that the bolt washer can be re-used, and install the bolt. Start engine and run for 2-3 minutes. Turn off engine and make sure that oil level is in correct level. Make sure that no oil is leaking."
After warming the scoot with a 5 mile run I removed the said bolts and let the grey/green oil drain...
After a cup of tea and a biscuit or two, I replaced the drain bolt. I measured 160ml of Syntrans and put it in... I then kept adding more expecting to see the oil level through the inspection/top-up hole. After I'd put 250ml in and I still couldn't see the oil level, I thought, hang on, the manual says 160ml but the manual innuendo says fill until you can see gear oil level with the inspection bolt hole...
I'm now confused, and your wisdom/opinion is needed for the ingredients in the soup of decision...
Sincere thanks in advance.
