Thoughts, experiences please
Tyre sizes
macp
- Current Ride: Gilera ST200
Tyre sizes
Has anyone considered changing the standard tyre size for instance the front on mine is 120/70-14 but I was reading of people going over to a 130/70-14 which apparently improves stability ?
- Dexter
- Current Ride: Push bike
Re: Tyre sizes
Whoever designed your bike probably knew what they were doing and chose appropriately sized tyres.
- irev
- Current Ride: AN400
Re: Tyre sizes
Moreover, whoever gave you that advice should show you their research and development credentials.
It's the kind of pathetic back-of-cornflakes-packet guidance from somebody who should be eating Farleys Rusks... take it, and die.
Clear?
Clear?
- Deeping
Re: Tyre sizes
If you put a wider tyre on to a rim it was not designed for you get less rubber on the road due to the centre of the tyre tread being pushed out to accommodate the extra width of the tyre.
Never instal version 1.0
macp
Re: Tyre sizes
Agreed and im not suggesting I know any better.Dexter wrote:Whoever designed your bike probably knew what they were doing and chose appropriately sized tyres.
macp
Re: Tyre sizes
First off take it easy buddyirev wrote:Moreover, whoever gave you that advice should show you their research and development credentials.
Clear?
- anonstarter
- Current Ride: Pending
Re: Tyre sizes
The Sym Citycom 300i front tyre is 110/70-16 whereas the 125cc version has 120/70-15. http://www.bennettsmotorcycles.co.uk/sym_citycom.asp
There have been discussions on Citycom forums which touch on considering the 'benefits' of a wider tyre:
The best route would be to buy good quality tyres and keep them at the right pressure!
However the general consensus seemed to be that it is not a good idea!A 120/70 - 16 front tire instead of the standard 110/70 - 16 would "fix" the optimistic speedo as it's circumference if 7% bigger. I just wonder how a wider tire would affect it's handling. I have heard that car/motorcycle manufacturers don't always put the best handling tire size/quality on their vehicles as they have to compete price-wise with their competitors. They go for the best compromise leaning more towards the cheaper side.
Re: Tyre sizes
It can be done...though I never have. In theory a wider tyre might give more grip, though it will make its handling less agile. Ought to be aware that it might change the speedo reading as well, though with the dodgy speedos that seem to be around, they might make it more accurate!
I did put slightly wider tyres on an ancient Fiat Panda I had once, and it definitely improved things. If I could have found a suitable wider tyre for my old Aprilia Atlantic I would have definitely tried it!!!!
Re: Tyre sizes
Hello Mac, yep...it can be done but may upset things a bit in the handling department. I once fitted a larger section rear tyre to my GSX1400 as a temporary stop gap. I know that's maybe a bit different in the size stakes. But considering it was just a very small increase from 195 to 200 section I didn't think it would matter much. The change in handling was lethal! I kid you not. I heard of others doing a similar thing with the front tyre also with similar effects. There is one other thing to think about, you prolly won't get insurance for it if you declare you have a modified tyre size on the bike as of course you must do. It's instant refusal from most insurers now for any non standard tyres on standard bikes as it is an untested modification in their eyes and has the potential to be dangerous.
- Deeping
Re: Tyre sizes
Data wrote:.There is one other thing to think about, you prolly won't get insurance for it if you declare you have a modified tyre size on the bike as of course you must do. It's instant refusal from most insurers now for any non standard tyres on standard bikes as it is an untested modification in their eyes and has the potential to be dangerous.
good one - I never thought of that
