The 2013 Burgman
The 2013 Burgman
Behold! The 2013 Burgman 650!!!!
http://www.scooter-station.com/Suzuki-B ... -best.html
Snag is, its exactly the same as the 2012 Burgman in all essential details............. :cry:
barryG
Re: The 2013 Burgman
Post by barryG »
Its now on Suzukis own website, yep pretty much the same :lol:
Yep, I was going to ask 'what's different?'. Could do with a slight styling freshen up me thinks.
barryG
Post by barryG »
All pure cosmetic, still the same bike so not new at all :D
Well there's definitely a few bits there Mr Meldrew, but as an on looker who's never owned a Burger it's difficult to spot any changes.
wozza wrote:Well there's definitely a few bits there Mr Meldrew, but as an on looker who's never owned a Burger it's difficult to spot any changes.
Yeah...its a slight restyle, rather than the completely new model that was trailed/promised/rumoured/speculated. Sorry Mr Suzuki, no sale....
bornagainbiker
Current Ride: Honda Forza 300
Post by bornagainbiker »
The main item I spotted from the technical specs on Suzuki Uk is that the current model and I presume all previous models have a 'Gear' Final drive but the new 2013 model is a Chain! More to service and replacement? I must admit having 5 geared cogs to drive the rear wheel is a bit unusual.
Current 2012 Specs http://www.suzuki-gb.co.uk/bike/an650al2/
DIMENSIONS AND WEIGHTS
Overall length: 2260mm (89in)
Overall width: 810mm (31.9in)
Overall height: 1435mm (56.5in)
Wheelbase: 1595mm (62.8in)
Seat height: 750mm (29.5in)
Kerb Mass: 277kg (610.7lbs)
Fuel capacity: 15.0litres (3.3 UK gallons)
ENGINE SPECIFICATIONS
Engine capacity: 638cc
Engine: 4-stroke, 2-cylinder, liquid-cooled, DOHC
Bore: 75.5mm x 71.3mm
Compression ratio: 11.2 : 1
Lubrication: Wet Sump
Ignition: Electronic ignition (Transistorised)
Fuel system: Fuel injection
Starter: Electric
Transmission: Computerised Suzuki Electronically-controlled Continuously Variable Transmission (SECVT)
Drive: Gear
CHASSIS SPECIFICATION
Front suspension: Telescopic, coil spring, oil damped
Rear suspension: Swingarm type, coil spring, oil damped
Front brakes: Disc, twin
Rear brakes: Disc
Front tyres: 120/70R15M/C 56H, tubeless
Rear tyres: 160/60R14M/C 65H, tubeless
New 2013 Specs (To be confirmed) http://www.suzuki-gb.co.uk/bike/an650zl3/
Overall length: 2270mm (89.4in)
Overall height: 1430mm (56.3in)
Wheelbase: 1590mm (62.6in)
Compression ratio: 11.2:1
Lubrication: Wet sump
Ignition: Electronic ignition (Transisorised)
Transmission: SECVT
Drive: Chain
Rear brakes: Disc
Seat height can be raised to 755mm
SPECIFICATION TO BE CONFIRMED
bornagainbiker wrote:The main item I spotted from the technical specs on Suzuki Uk is that the current model and I presume all previous models have a 'Gear' Final drive but the new 2013 model is a Chain! More to service and replacement? I must admit having 5 geared cogs to drive the rear wheel is a bit unusual.
Interesting. There aren't many photos of its LH side, but it appears to be enclosed, so I'd guess they have adopted the old TMax/ new BMW enclosed chain system, which would make a lot of sense. The enclosed chain systems required very little maintenance and are rather lighter than the chain of gears on the old models which was always rather an over complex solution. Interestingly, they don't quote a weight for the new model. They needed to put in on a major diet - getting rid of the cogs is a good start, but that appears to be it.
The claim it will be 15% more economical, whatever that means.
Is it only me that thinks they copied sym maxsym for the rear light shapes? Even the front headlights resemble a copy design... Boring...
Normsthename
Post by Normsthename »
Wonder how the 'Eco Drive' will work?
1975 Honda GL1000 Goldwing
