Maxi-muppets :D
- SOLO
- Current Ride: Piaggio X9 500
Maxi-muppets :D
Done:
SOLO-Yorkshire.Biker ( Squires Bikers Founder ) * ride Piaggio X9 500 ( Dave Miles old X9 )
- Deeping
Re: Maxi-muppets :D
I see that you took it on a Digital Camera FinePix S6500fd on 04/01/2006 18:00 (You may want to reset the date on your camera’s software) and settings f/8 1/400sec exposure with an ISO of 200 with flash on compulsory with a 6mm focal length lens. The brightness was 8.26 in portrait mode, sharpness set to normal and white balance set to auto and Bit Depth was 24. Its 640 by 480 with a resolution of 72dpi
Is it not amazing how much information we give away for free
Never instal version 1.0
- jjprivate
- Current Ride: X9 125 2001
Re: Maxi-muppets :D
nice Solo, now your scoot is street lagal, hehehe
- SOLO
Re: Maxi-muppets :D
Deeping that ace how did u get that ?
- Ferrit
- Current Ride: MP3 400ie
Re: Maxi-muppets :D
It is saved with every photo you take.
- Deeping
- SOLO
Re: Maxi-muppets :D
Cool, but i cant see it, i know its saved with every photo i take and can see it on my own pc, but how can other people see it online, where do you look ? all i see id the photo on this thread.
darrenandsarah
- Current Ride: T-Max Mk3
Re: Maxi-muppets :D
Not exactly his bank details and pin number though is itDeeping wrote:I see that you took it on a Digital Camera FinePix S6500fd on 04/01/2006 18:00 (You may want to reset the date on your camera’s software) and settings f/8 1/400sec exposure with an ISO of 200 with flash on compulsory with a 6mm focal length lens. The brightness was 8.26 in portrait mode, sharpness set to normal and white balance set to auto and Bit Depth was 24. Its 640 by 480 with a resolution of 72dpi
- Deeping
Re: Maxi-muppets :D
If you take it on a mobile phone with GPS turned on it will also show the location.darrenandsarah wrote:Not exactly his bank details and pin number though is itDeeping wrote:I see that you took it on a Digital Camera FinePix S6500fd on 04/01/2006 18:00 (You may want to reset the date on your camera’s software) and settings f/8 1/400sec exposure with an ISO of 200 with flash on compulsory with a 6mm focal length lens. The brightness was 8.26 in portrait mode, sharpness set to normal and white balance set to auto and Bit Depth was 24. Its 640 by 480 with a resolution of 72dpi
So if taken at home, people including thieves will know where it is – does this not bother you?
