So then, VOSA finished the enquiry and have sent me an email.
resulting in unstable combustion and the stall condition.
'THE STALL CONDITION'? - THE DEATH CONDITION - HONDA ARE A BUNCH OF XXXXX
Our ref: VSD 24581
28 January 2013
Dear Mr XXXXXXXX
HONDA MOTORCYCLES SH300i - ENGINE CAN STALL
Following investigation, Honda Motorcycles have established that with the engine
idling and the centrifugal clutch disengaged, if the throttle is opened slowly to about 2
degrees it can cause the fuel injection system to over fuel and cause an over rich
mixture, resulting in unstable combustion and the stall condition. The issue is similar
to the recall issue, but only affects a very small number of machines. To address the
issue, Honda have remapped the engine ECU. They will use the new ECU for any
outstanding machines affected by the recall and will also replace any ECU's on any
machine where it is reported to have experience the same issue.
I believe that Honda have dealt with the issue on your machine by replacing it with a
later model.
I would like to thank you for raising the issue with VOSA and should you wish to
discuss this matter in more detail please do not hesitate to contact me.
Honda SH300 engine stalling Jan. 2013 update IMPORTANT
EDW
- Current Ride: HondaSH300
- StephenC
- Current Ride: Kymco DT X360
Re: Honda SH300 engine stalling Jan. 2013 update IMPORTANT
Result. Well done.
But I'm confused by the reference to Flat C at the end. Is that some kind of fanfare you're entitled to sound as a result?
Can is not the same as Should
richie the 1st
When i had my sh300i,it did stall once.That was on the way back from picking it up.
However in 55000 miles on 2 Honda sh125.Never have they ever stalled.
Old honda sh125.
New Honda sh125.
Ride free,ride safe.
New Honda sh125.
